Toggle navigation
Login
Register
Welcome,Guest
1 Hour
1 Day
1 Week
1 Month
Forever
4x4 Related Groups
Tech Talk
overheating
« previous
next »
Print
Pages: [
1
2
Go Down
Author
Topic: overheating (Read 2410 times)
giorno71
Baby Wheeler
overheating
on:
July 30, 2009, 08:56:05 PM »
Just put a 4.0 l in my yj now it keeps overheating. do i have to upgrsde the rad. it's curently the stock from the 2.5. the water pump workes fine and i changed the thermostat.
Logged
Whips17
Baby Wheeler
Re: overheating
Reply #1 on:
July 30, 2009, 09:06:02 PM »
When I upgraded my motor I had to up grade my rad from a 2 core to a 4 core and it made a big diff, also a electic fan will also make a big diff not only in cooling but thotle responce also.
Logged
80 CJ-7 350 chevy, 8000 Warn winch, 33/12.5 R15 Cooper STT, True Trac front & Rear,
giorno71
Baby Wheeler
Re: overheating
Reply #2 on:
July 30, 2009, 10:15:00 PM »
ya i have 2 eletric fans one pusher and one puller
Logged
JackstandJohnny
Talks waaay too much!
where Jeeps go to die
Re: overheating
Reply #3 on:
July 30, 2009, 10:24:54 PM »
is the 4.0L good? blown headgasket may cause that......
Logged
~ rescue green JKUR on 35s. typical rubicon build
giorno71
Baby Wheeler
Re: overheating
Reply #4 on:
July 30, 2009, 10:34:42 PM »
Took it out of a 92 xj took the xj from medicine hat to calgary and back and temp never went over 100 about a 3 hour drive each way, now i cant make it 5 min out of town and have to pull over and let it cool down
Last Edit: July 30, 2009, 10:37:01 PM by giorno71
Logged
dunl
Re: overheating
Reply #5 on:
July 30, 2009, 10:41:31 PM »
Air bubble?
Logged
`48 CJ2A, `54 CJ3B, `97 TJ, and 03 WJ...batting close to .500 when it comes to jeep models owned vs. jeep models created.....
Red Deer Jeep Packrats
www.reddeerjeep.com
giorno71
Baby Wheeler
Re: overheating
Reply #6 on:
July 30, 2009, 10:44:27 PM »
Dont think so flushed the system twice and new antifreeze. even changed the temp sender
Logged
JackstandJohnny
Re: overheating
Reply #7 on:
July 30, 2009, 10:47:19 PM »
thats weird dude. mine is running a stock 2.5L rad and its nice and cool. what size tires? stock XJ, big YJ? isn't running a pusher/puller setup counter productive? (i am unsure of this)
maybe the rad is no good?
Logged
giorno71
Baby Wheeler
Re: overheating
Reply #8 on:
July 30, 2009, 10:50:53 PM »
running 31X 10.50 tires and my 2.5 never had a problem with it and if i disconnect the pusher fan the temp goes up faster. i havent presure tested the rad but i tried the garden hose in the top port to see if i had lots of flow through it and it came out almost as fast as it went in
Last Edit: July 30, 2009, 10:59:36 PM by giorno71
Logged
JENSSEN
Re: overheating
Reply #9 on:
July 31, 2009, 08:17:00 AM »
Check your fuel pressure
Lean = HOT!
Logged
www.racingforthecure.ca
slimbeam
UberWheeler
4" RE,3"body,35"rubber,dana 44 rear,sye,KEW winch
Re: overheating
Reply #10 on:
July 31, 2009, 08:26:21 AM »
some water pumps are forward rotating (2.5 + 4.2L with "V" drive belts) the 4.2L + 4.L and 2.5L with serpentine belt is reverse rotating. you may have the wrong pump for your setup
Logged
I started out with nothing and so far I have most of it left
giorno71
Baby Wheeler
Re: overheating
Reply #11 on:
August 01, 2009, 12:30:33 AM »
i have a infared temp gun to... but thanks . the water pump on the motor was on it when i did the swaped and it worked fine in the xj. changed the rad cap this evening will test it tommorow. also someone told me you can use clr to disolive corosion in the rad... has anyone tried this? seems kinda sketcy to me but the last thing i wanna do is buy a new rad and that not b the problem.
Logged
barmanjay
That CB Yapper
Wanna buy a trail? or Garage w/attached house?
Re: overheating
Reply #12 on:
August 01, 2009, 11:20:45 AM »
The t-stat is installed the right way?
Logged
The realtor that gets dirty
Dirty Old YJ , 4" spring lift and 33's - Sold - *snif*
300C SRT8 - Workmobile
Jason Kim
Realtor
Maxwell City Central
889-4747
www.jaykim.ca
giorno71
Baby Wheeler
Re: overheating
Reply #13 on:
August 01, 2009, 06:44:44 PM »
yep it is double checked that
Logged
BlackYJ
Re: overheating
Reply #14 on:
August 04, 2009, 07:18:50 AM »
The rads are the same between the 2.5 L and 4.0L.
Is the rad clogged with mud? Do you have a winch blocking the rad?
Logged
Print
Pages: [
1
2
Go Up
« previous
next »
4x4 Related Groups
Tech Talk
overheating
