Author Topic: Xfer and tranny fluid...  (Read 2245 times)
Jaguar
« on: May 24, 2005, 06:25:01 PM »
It's definately time to change these! What do I use, and where can I find it?
Thanks!!
Michael
90YJGIMP
« Reply #1 on: May 24, 2005, 07:08:24 PM »
Might help to let us know the type of jeep and whether you have a manual or automatic tranny..
Troy
« Reply #2 on: May 24, 2005, 07:43:22 PM »
The t-case should be ATF and for the tranny, if it is a manual then 80W-90 gear oil and auto is ATF
Jaguar
« Reply #3 on: May 24, 2005, 08:09:27 PM »
D'OH!!!! sorry, I was too excited to finaly post again :)
2003 Jeep TJ Manual tranny.
I thought there was special fluids that were supposed to go in the two, not just ATF and 80W-90  :?
« Reply #4 on: May 24, 2005, 09:25:22 PM »
check the owner's manual but that is what usually goes in the Jeep t-case and tranny.  Now if you have a limited slip in the rear diff, you are suppose to add a friction modifier
Offline Rookie
« Reply #5 on: May 25, 2005, 11:33:12 PM »
The t-case is atf+4 (dealer item) the man tranny is Mopar manual transmission lubricant (dealer item $14 per liter u need 2)that being said I have read that according to NVG (the tranny manufactuer) that the trans uses regular 5w30 motor oil do a search  here for the thread on trans fluid to read the whole story (using 5w30 is surpossed to reduce the "marbels in the tranny sound')
HTH
Steve
TJ with some stuff
gsxtacy
« Reply #6 on: December 07, 2005, 03:35:16 PM »
bump
 8)  8)  :shock:  :shock:
 :)  :D  :P
