Author Topic: steering fluid lost  (Read 2330 times)
ryetarded
steering fluid lost
« on: January 02, 2006, 09:34:42 PM »
I noticed my steering was getting noisy. when i checked the level there was ummmm... NONE  :?
i filled it up drove it home and noticed fluid leaking by my steering gear box . I thought it would be my pump but it seems fine.
any suggestions on what approach i need to rectify this problem other then cracking eggs :shock:  into my jeep would be greatly appriciated ...
Greg
henry
Leak
« Reply #1 on: January 02, 2006, 09:50:56 PM »
Shampoo your engine area off, get all existing leaked oil cleaned from around where you think the power steering system is leaking.  Take it for a drive, see where the new oil is that leaked out, and theres your problem.  Probably just a power steering hose, no biggie.
Darren
Offline RckyMtnTJ
    • http://www3.telus.net/lck
steering fluid lost
« Reply #2 on: January 02, 2006, 10:27:09 PM »
I don't know what you drive, but TJ's are known to leak from the seal at the bottom of the steering box where the pitman arm connects.  I replaced mine with a Grand Wagoneer early 80's vintage steering box.
HTH
98 TJ 4" lift + goodies
Offline apex
steering fluid lost
« Reply #3 on: January 04, 2006, 03:20:49 PM »
Quote from: "RckyMtnTJ"
HTH
that is exactly where mine is leaking from too. replacement seems to be best option as it is a cronic problem with the stock box????
Offline Elsifer
steering fluid lost
« Reply #4 on: January 04, 2006, 07:00:33 PM »
The stock box is ok, but for larger tires it may be underpowered. I have heard (and someone will need to confirm this). That a same year Durango streering box is a direct bolt in fit. Bigger and beefier so I have heard.
Your milage may vary.
VA6CPL
Jeepless....
Offline Gearhead
steering fluid lost
« Reply #5 on: January 05, 2006, 08:08:47 AM »
Confirmation of the above ?????????????
ryetarded
steering fluid lost
« Reply #6 on: January 07, 2006, 02:46:58 PM »
sorry, i have an 01 tj with 35 pro comp x terrains
that would be great if i could do a direct swap with a durango
let me know about this im gonna check the price of a durango box ...i think my nieghbor owns a durango he wouldn't miss his .
my shop has qouted me $500 to go with an aftermarket box ...as they are covering the cost of the fix they would put the aftermarket one in for free
i really appriciate your responses
ryetarded
steering fluid lost
« Reply #7 on: January 07, 2006, 02:52:47 PM »
I just found some pics of a guy swapping in a durango steering box take a look
http://jeepin.net/photos/durango
looks easy
steering fluid lost
« Reply #8 on: January 09, 2006, 03:04:52 PM »
PM rackman for details, or head over to JU.
If rackman is around he'd be better to get info from, he's local and somone who's actually done.
IIRC you need a 1999-2002 durango box out of a V8
