Author Topic: comanche lift  (Read 1805 times)
Offline pitter085
  • new jeep
comanche lift
« on: February 07, 2010, 06:25:27 PM »
im new to this kind of thing , but how do i lift the rear of a 90 comanche? i bought stuff from a guy off here for the front.  any info would help thanks guys
Offline OffRoadNewbie
  • I Blame Keith !!
Re: comanche lift
« Reply #1 on: February 07, 2010, 06:33:39 PM »
i have a 60" farmers jack will that help ??  :P ;D
2006 TJ its Green !! ;)
Offline pitter085
  • new jeep
Re: comanche lift
« Reply #2 on: February 07, 2010, 06:35:06 PM »
your funny kyle
Re: comanche lift
« Reply #3 on: February 07, 2010, 06:48:31 PM »
Comanche's are a separate thing.  NOTHING, and I mean NOTHING bolts in directly.
I would PM Waytec....I think a friend of his had a Comanche lift coming into a shop in Edmonton that he might have been parting out.
Re: comanche lift
« Reply #4 on: February 07, 2010, 08:06:15 PM »
How much do you want to lift it?  Since is a sprung under axle setup in the rear the simplest thing to do is grind off the spring perches and have them re-welded onto the top side of the axle. This will net you about 5-6" though....
Offline pitter085
  • new jeep
Re: comanche lift
« Reply #5 on: February 08, 2010, 01:26:58 AM »
if  i flip the rear what esle will i have to do? brake lines drive shaft? like i said im new to this lol
Offline stroker sahara
Re: comanche lift
« Reply #6 on: February 08, 2010, 06:07:47 PM »
When I did a SOA on my Comanche, I also put in an Explorer 8.8. The pinion yoke moved +/- 1" forward which made the use of the stock driveshaft acceptable, although it is a goo idea to do a SYE to eliminate the slight vibes. If you plan to retain the stock rear prop valve, you will have to lengthen the linkage. One concern of SOA is axle wrap, which I didn't notice until I put tire chains on.
Offline comanche killer
  • Aaron
Re: comanche lift
« Reply #7 on: February 08, 2010, 08:54:41 PM »
p'md
95 3/4 ton Chev  dailydriver/heavy hauler
97 green MZJ custom 4link rear/3link front, FF 14 bolt rear welded, D 60 front, ax-15, np-231,custom rollcage, half doors, PSC hydro assist 14"kings 40"boggers
