Author Topic: problem  (Read 4888 times)
PITBULL
problem
« on: March 10, 2010, 07:40:04 AM »
went to go start the jeep after work yesterday cause i was cleaning it out and wanted to stay warm
i turn the key and hear CLICK CLICK CLICK ........
i tried jumping it still CLICK CLICK CLICK ......
I think its my starter anyone have this problem befor
Offline Black Betty
Re: problem
« Reply #1 on: March 10, 2010, 07:49:32 AM »
I had that problem before, try giving it a few taps with a hammer, sounds funny but it sometimes works!
Stupid hurts
PITBULL
Re: problem
« Reply #2 on: March 10, 2010, 07:51:15 AM »
yeah did that and nothing ....
but it should be a safe bet to get a new starter right?
Offline Justink
  • '89 comanche 5'' lift, 33's
Re: problem
« Reply #3 on: March 10, 2010, 07:57:06 AM »
Try putting power right to the starter.  Has your starter ever dragged before this?  If so your probably safe to get a new starter.
'91 cherokee 4.5'' 31's DD
'88 Nissan 300zx just for fun
PITBULL
Re: problem
« Reply #4 on: March 10, 2010, 07:59:03 AM »
i just bought this jeep about a week ago so im not sure lol
like im not upset or anything expected something to go wrong ill try the starter tonight and see what happens
Offline Black Betty
Re: problem
« Reply #5 on: March 10, 2010, 08:00:22 AM »
I think crappy tire will test your starter for you, may be worth while to try that.  Guess it could be the relay too though.  Try putting power right to it, you'll know then.
Stupid hurts
PITBULL
Re: problem
« Reply #6 on: March 10, 2010, 08:25:23 AM »
THIS IS A DUMB QUESTION LOL
BUT HOW DO YOU PUT POWER TIGHT TO IT ? NEVER EVEN NEW I COULD DO THAT
Re: problem
« Reply #7 on: March 10, 2010, 08:36:30 AM »
is your battery dead?
PITBULL
Re: problem
« Reply #8 on: March 10, 2010, 09:24:10 AM »
YEAH IT IS BUT THIS HAPPENED BEFOR IT DIED
Re: problem
« Reply #9 on: March 10, 2010, 09:40:59 AM »
From my experience, usually if the starter is just clicking, that means that the solenoid is not getting enough power from the battery and hence the battery needs to be replaced
Re: problem
« Reply #10 on: March 10, 2010, 09:48:35 AM »
the clicking is usually the solenoid engaging the starting gear (which requires low current).  it means the starter motor is not turning (which requires high current).
when the solenoid goes, the starter spins and screams and that is when you usually can use a hammer to loosen up the solenoid or the battery is too low.
if yu dont know how to jump a starter, dont try.  last thing we need to hear is your jeep ran over you.
PITBULL
Re: problem
« Reply #11 on: March 10, 2010, 10:08:29 AM »
TO FUNNY LOL
WELL ILL GO OUT AND GET IT TESTED THE WORST ILL HAVE TO DO IS BUY A NEW ONE NOT TO BAD
Offline Justink
Re: problem
« Reply #12 on: March 10, 2010, 10:28:29 AM »
follow your power wire down to the starter and hook a booster cable or battery charger directly onto where the power wire goes
Re: problem
« Reply #13 on: March 10, 2010, 11:21:58 AM »
stop talking in capslock. its annoying ;)
how long did you turn it over before it died? did you crank it for half an hour? or did it go click, click, click, dead?
diagnose;
your starter is NOT getting juice.  thats either the battery or solenoid.  if starter was getting juice it'd whine loud.
start with the cheap things; hook jeep up to a new battery.  if it still doesn't start its the solenoid.
i'll bet you a donut your battery is dead.
PITBULL
Re: problem
« Reply #14 on: March 10, 2010, 11:26:40 AM »
caps lock is on cause i have to keep it on to work in a program at work lol
and ill try that to night and let you know
