Author Topic: Rear steer  (Read 1994 times)
CanaMatt
Rear steer
« on: January 27, 2006, 12:36:13 AM »
Is building a rear steer rig hard, or is there a company that sells these. I haven't really read about it, only seen it in the mags. The major issue would be locking the rear up so it can drive straight when you want a normal set up.   I doubt you can just use a front axle in the rear because the gears would be reversed.
Rear steer
« Reply #1 on: January 27, 2006, 07:41:54 AM »
Check out the 4 Wheeler website under the rig build-ups, there is a guy, Wolf 359 or something building a buggy with rear steer.
Offline Robb
    • Calgary Real Estate
Rear steer
« Reply #2 on: January 27, 2006, 07:58:53 AM »
Diamond Dave had rear steer in his first buggy,   Basically a Pump, Hand lever, and a piston to the rear axle.
He didn't have any way of telling when it was centred other than looking out at the back wheels.  Someone else too a die cutter to a part of the piston that didn't go into the ram, and installed a reed switch to light up a "centered" light on the dash.
Pretty wizzy stuff if you ask me.
Offline redbull
Rear steer
« Reply #3 on: January 27, 2006, 09:19:11 AM »
Some rigs I've read about had a pin to lock the center when you didn't want the rear to steer.
I doubt any home built rear steer system would be legal though.
yjpaul
Rear steer
« Reply #4 on: January 28, 2006, 02:12:51 AM »
Quote from: "redbull"
Since when has illegal modifications stopped any of us  :twisted:
Jaguar
Rear steer
« Reply #5 on: January 28, 2006, 02:05:25 PM »
Na, should be fine if you only drive in reverse on the streets ;)
