Author Topic: Bushman's XJ Build  (Read 8889 times)
Offline bushman67
  • "Alright, I've got four dollars, almost five"
Bushman's XJ Build
« on: April 25, 2010, 04:17:10 PM »
What the heck! Guess I'll start a build thread. Who knows where it could lead.
Before: The budget buy end of march - 1996 XJ, green, saggy, 217,000km, body good shape, minor issues.
« Last Edit: June 03, 2010, 11:02:11 PM by bushman67 »
Economy has me demoted to "token photo-boy"
Offline bushman67
Re: Bushman's XJ Build
« Reply #1 on: April 25, 2010, 04:26:30 PM »
-- 3" skyjacker coils, RE disco's, RE 3.5" spring packs.
-- Actual lift 5" from "new" XJ specs... just over 6" gained due to saggy suspension.
Offline bushman67
« Reply #2 on: April 25, 2010, 04:34:51 PM »
First drive had nasty vibes, so I fab'd some 1.5" tcase drops. Avoided pulling the stud by bolting the square stock to the frame, then the cross member to the square stock with short bolt & nylock. Sorry no pic of that bit.
Some vibes fixed, but not enough, so added home made shims of 1/4" bar stock with noches cut out to lock them into place with the u-bolts. Worked pretty good... vibes were still present, but tolerable for now. But was running a dying D35... Pinion pooched, and limited slip issues. Swapped out for an 8.25, and a 1/2" shorter drive shaft.
Time to save for an SYE.
Offline bushman67
« Reply #3 on: April 25, 2010, 05:19:24 PM »
- Rubber rocker stripped gone, and rockers repainted with rocker guard and clear coat + pin stripe to break colors. Front bumper rock-guarded
- Rear end replaced yesterday, and Ecco wheels with used 235 desert duelers today... and mud courtesy of the bloody snow storm last night.
Offline bushman67
« Reply #4 on: May 26, 2010, 04:47:17 PM »
Just an update... still battling with a driveline vibration after doing the hack & tap a while ago, where I found that my tcase output shaft has a "wobble"
I got two different tcases and hopefully fix what ails me. Upon pulling my NP242J (from the 96) I found that the vacuum switches between mine and both the 99 & 97 NP242J tcase I have on hand are different... both in location & plug. Have no fear, it seems that you can just wrench out the sensor, and swap them, and reroute the wiring harness.
Also found that very minor play in my RE track bar led to a couple of death wobble experiences at 100km/h after hitting a seam in the pavement. YIKES.... rebuild kit installed :)
Now onto redoing axle ujoints...
Offline apeman
  • not as grumpy
« Reply #5 on: May 27, 2010, 04:02:15 AM »
I like the coils and control arms...lol too bad the shocks didnt work out for you..
Getting grumpier every day.
Offline bushman67
« Reply #6 on: June 03, 2010, 09:11:11 PM »
Just some new pix after new shackles and spacers... plus some 'borrowed' 31" rubber (thanks fug!)
« Reply #7 on: June 03, 2010, 09:17:45 PM »
She's looking sweet!
Offline Rich99
« Reply #8 on: June 03, 2010, 10:28:20 PM »
Nice! What a difference from the original shot.
Is that death wobble gone?
Rich.
Offline bushman67
« Reply #9 on: June 03, 2010, 10:59:56 PM »
New bushing & hiem joint fixed all the play in the track bar, but I still had another death wobble experience after hitting a good overpass seam at 100km/h.
I know I have exsesive toe-in right now, and is obviously a contributor to the death wobble, however, after running without my discos for two days I think I found what starts it... I'm pretty sure my FR shock is toast.... this 'bounce' and the toe-in would get any front end slamming back & forth.  My alignment is tomorrow (Friday) anyway.... then I'll check into new front shocks.
« Reply #10 on: June 04, 2010, 08:27:03 AM »
rob that won't cause death wobble ;)
when you come by tomorrow we'll take a look and see what has play in it. i bet track bar......... its always the trackbar ;)
Offline bushman67
« Reply #11 on: June 04, 2010, 08:35:13 AM »
Track bar is tighter than tight... new bushing, bolt, heim joint, etc. No play that I can find. I was actually talking to Fenton's in Cochrane, and even with the track bar tight, he's seen impact induced death wobble.
Offline Pookapotamus
« Reply #12 on: June 04, 2010, 08:59:16 AM »
my death woble was my ball joints, have you replaced them or inspected them yet?
Offline bushman67
« Reply #13 on: June 05, 2010, 08:30:42 PM »
I just had all steering components checked over when I had my alignment on Friday.. all checks out ok.. my toe-in problem could have easily started my death wobble when hitting potholes or bad overpass seam. I still have a suspect shock, and the stock steering stabilizer could very well be pooched.
Offline esi
« Reply #14 on: June 06, 2010, 01:48:19 AM »
Steering stabalizers don't cause DW, they just hide it for a while :)
Formerly of Boots & Boost Inc
