Author Topic: Anyone with a pipe bender?  (Read 3130 times)
Offline apeman
  • not as grumpy
« on: April 30, 2010, 05:55:29 AM »
Im looking to bend some 1.5" std wall pipe .120, for a prerunner hoop for the bumper i built...understandably a case of beer may be involved....
Getting grumpier every day.
Re: Anyone with a pipe bender?
« Reply #1 on: April 30, 2010, 07:07:52 AM »
I have a tube bender but not pipe. Both 6" and 4" radius dies. I dont drink, but cash is acceptable.
I'll be in the shop all day tomorrow if you need to do a bend.
Offline apeman
  • not as grumpy
« Reply #2 on: April 30, 2010, 12:32:24 PM »
hmmm, this isnt tube, its pipe, i dont know if it will want to bend easily enough...?
« Reply #3 on: April 30, 2010, 01:22:06 PM »
Ahhhh... tube vs pipe
I suspect you have tube and want a tube bender...
Structural Tube - high strength welded steel tubing
Mechanical Tube - seamless, as-welded and drawn over mandrel
Standard Pipe - several seamless or electric weld process, carries liquid or gas
Tube has consistent OD and wall thickness. you would use DOM 'tubing' for a roll cage.
Pipe - think of it as carrying gas or liquid.  Iron pipe or copper pipe for instance.
And sorry for the upcoming hijack...
Billy -  want sizes of tube dies do you have?
Offline apeman
  • not as grumpy
« Reply #4 on: April 30, 2010, 01:59:45 PM »
aaaaah...nope..im a welder and quite familiar with pipe and thier grades/types...this is 1.5" std wall seamless pipe...chances ae it will damage a tube bender....i may have to just put in  the hydro press and take my chances, but that weakens the pipe...but its just a prerunner hoop..so who cares...
« Reply #5 on: April 30, 2010, 02:27:01 PM »
sorry about that... didn't know you knew what you were talking about!   ;D   I'll go back to my little corner of the world now...
« Reply #6 on: May 03, 2010, 06:40:53 AM »
1.5" and 1.75" Kev
Offline Raspberry
« Reply #7 on: May 07, 2010, 11:05:58 PM »
Sorry to hijack the OP's thread, but I'm possibly looking to have a piece of exhaust tube/pipe(?) bent... I want to remove the muffler + catalytic converter and replace with a straight-pipe. Do I even need to have it bent? If so, can someone kindly point me in the right direction?
The reason I'm doing this is I've now broken my 3rd XJ muffler... and am getting sick and tired of it all. First two got ripped off by getting high-centred on rocks on the trail. This 3rd time, the rear driveshaft disconnected at the axle end and flailed around, tearing a hole in the muffler. I'd rather be rid of this annoyance! I've considered some other muffler-replacement options, but I'm constantly broke, which makes me cheap! I prefer cheaper options!
Suggestions appreciated :)
Offline Elsifer
« Reply #8 on: May 17, 2010, 10:00:35 PM »
Go to any large size plumbing shop, and get a couple of butt-weld long radius 90's. Mitre them accordingly, and weld em out. Prolly like $5 for one BW LR 90
Or talk to Triple D Bending. $$$$
VA6CPL
Jeepless....
Offline apeman
  • not as grumpy
« Reply #9 on: May 18, 2010, 03:43:17 AM »
i actually just used the 100T hydraulic press at work to make the bends...originally used my oxy acetylene torch to heat , then bent the pipe, but bends werent consistent...but thanks anyhow...
P.S Special K..i didnt mean to sound like a jerk, just needed to clarify that it was indeed pipe..not tube.. ::)
« Reply #10 on: May 18, 2010, 07:45:18 AM »
Degree bending or Compass bending are cheaper
