Author Topic: ZJ rear winch bumper with tire carrier  (Read 11084 times)
« on: May 03, 2010, 11:17:05 PM »
Finally got the tire off the roof.  =D>  The pivot is a trailer axle with the flange cut off. Probably spent as much time reinforcing the rear unibody as I did building the darn thing.... Thats a 36X13.5 tire on there, it will take a 37X15.
Re: ZJ rear winch bumper with tire carrier
« Reply #1 on: May 04, 2010, 08:41:50 AM »
looks awesome Clay!
Offline .:.Dingman.:.
« Reply #2 on: May 04, 2010, 10:00:22 AM »
Looks sick, let me be the first to say post more pictures!!!
Dingman
Offline apeman
  • not as grumpy
« Reply #3 on: May 04, 2010, 01:38:01 PM »
Awesome design....love the integrated winch. 8)
Getting grumpier every day.
« Reply #4 on: May 04, 2010, 07:19:31 PM »
Nice Craftsmanship  8)
How is it attached to the unibody?
« Reply #5 on: May 04, 2010, 08:39:41 PM »
The outside of the unibody was sleeved with some angle iron welded on. Then some 2X4 box tubing was slid into the inside of the unibody. The box tube has nuts welded inside of it(like the factory nut strip). Then the original bolts that hold on the gas tank skid and trailer hitch are reinstalled(minus the hitch) and thread into the nuts in the box tube. I also installed some extra bolts horizontally thru the unibody to give it lateral support.
The back end mounting area of a ZJ is even weaker than an XJ.
Offline bradley
« Reply #6 on: November 05, 2011, 08:50:43 PM »
that is a nice bumper, great job, what did u make for the front
2002 jeep tj, 7 inch lift with long arm front and triangulated 4 link rear, 37x12.5x15 maxxis creepy crawler tires, custom front and rear bumpers, 12000 winch, G2 dana 44 front with detroit locker, 44 rear with spool, custom rear skins and flares, sye kit
« Reply #7 on: November 05, 2011, 10:03:26 PM »
Went pretty simple/basic for the front. 4" plate tube stuffed into the frame and a winch plate welded between them. Not stylish but extremely functional and maximizes approach angles.
Yes, thats a home made, Princess Auto ram assist setup doing its thing in Moab. ;) Sure wish I was there right now!
Offline bradley
« Reply #8 on: November 06, 2011, 08:21:36 AM »
not to shabby, the reason i ask is i am about to build bumpers for my zj and am trying to get some ideas, also what lift did u put on yours and where u get it and how much if u dont mind me asking??
« Reply #9 on: November 06, 2011, 08:49:23 AM »
The lift kit is from the US. Its from Clayton's offroad and is their 8" long arm kit. Its about the beefiest/biggest kit their is for the ZJ and 5 years ago cost me around $3500 for just the lift kit.
« Reply #10 on: November 06, 2011, 08:52:08 AM »
Check out www.mallcrawlin.com for hardcore ZJ advice and www.nagca.com for moderate ZJ mods.
Offline bradley
« Reply #11 on: November 06, 2011, 09:04:26 AM »
Thanks man i appreciate the advice, i dont know if i quite need a 8 inch lift, i am just lookin for enough lift to get a set of 33 inch tractor tires that i had on my last rig under the zj, i think a 4 inch short arm might do the trick with some fender trimming. If u got anymore words of wisdom on zj's dont b affraid to put them out there.
keep the rubber side down
« Reply #12 on: November 06, 2011, 11:04:49 AM »
More advice? Sell it and buy an xj. Cheaper/easier to build. They are lighter and smaller so they work better off road. More aftermarket support for xjs so more choice and cheaper prices.
If you still want to daily drive it keep it under 4" of lift and 33s.
« Reply #13 on: November 06, 2011, 11:54:45 AM »
This is so true. I'm at just under 6" with LAs and 33's and it can get a bit weird on the road, especially in winter. These need a beefy steering upgrade when you go 31"+, I'm probably going to take Bnine's advice and go Currie. But I'll wait and see what Evolution comes out with.
« Reply #14 on: November 06, 2011, 12:51:11 PM »
Also I actually prefer the stability that the rear leafs on the xj give. Yes the rear coils on my zj flex better, but not that much better and sometimes they act a bit weird, doing sudden weight tranfers at bad times. Never got that with leafs.
I like the v8 though. :) So wish they made a v8 xj.
