Author Topic: I had my jeep up on the lift and noticed 3 things  (Read 4136 times)
Offline Jrama
« on: June 02, 2010, 07:08:56 PM »
1. My caster bolt came loose and was out of alignment.....2nd time
2. Have a trac lock lsd
3. Excessive play on both sides when pushing the wheel side to side on the  D30
My main concern is #3, the driverside has Lots of play  when I push it I can actually see the U joint  move alittle along with the axle shaft. The Jeep drives completely normal and shows no signs of this problem. Now I installed an aussie locker in this axle over a month ago and its been working fine since.
 I have heard this "play" is a sign of bad hub unit. Again no problem except the play which I know is not normal, any advice? I'm tempted to ignore it....but I know better
And yes, the wheels are bolted on tight, and everybolt near the knuckle is tight as it should be
Edit: I don't think its a hub unit due to the fact the jeep only has 40k kms
YoungFluff03TJ
Re: I had my jeep up on the lift and noticed 3 things
« Reply #1 on: June 02, 2010, 07:59:16 PM »
U joints
Offline Jrama
« Reply #2 on: June 02, 2010, 08:44:14 PM »
U joints are rock solid and don't budge a millimeter, the whole axle shaft and U joint move togther.
Seems like the Unit bearings are on their way out. Mud causes premature wear, I am just going to keep an eye on it for now.... watch the tire wear. Probably wait until it gets worse before I do anything. its odd that both the driver and passenger side went at the same time.
« Last Edit: June 02, 2010, 09:19:38 PM by Jrama »
« Reply #3 on: June 02, 2010, 09:17:14 PM »
Isn't that the unit bearing, then?
Offline Jrama
« Reply #4 on: June 02, 2010, 09:30:38 PM »
Yeah i guess i was in denial and posted a pointless thread....  the jeeps got 40K its an 04 and I have only owned it for 1 year june 16th. It's never been offroad before i got it and I have only done mud like 4 times in the year I've owned it. I am still running the stock rims with stock  back spacing. Givin that they both have playI am entering anger stage right now.
« Last Edit: June 02, 2010, 09:41:05 PM by Jrama »
« Reply #5 on: June 02, 2010, 10:15:39 PM »
you drive a jeep. get used to it.
mud = destruction of parts........... don't get angry at it man.  just learn how to swap them out so they dont' cost you an arm and a leg.
on a semi seriously note; stuff like this you have to learn, otherwise wheeling will be a very expensive sport for you.........
« Reply #6 on: June 02, 2010, 10:20:13 PM »
Where the keys in the ignition and the steering wheel locked at the time of the tire wiggle?
« Reply #7 on: June 02, 2010, 11:04:16 PM »
if its your unit bearing i would change them both out
and do it befor they seporate and then you loose your wheel while driving
ive replaced mine 3 times in just under 2 years . get used to it
Offline Jrama
« Reply #8 on: June 02, 2010, 11:42:21 PM »
No the keys weren't in etc etc. but after taking the rotor off it was obvious what was loose
3 bearings in 2 years Yes it does Sound like its going to be regular maintenance,Hell yes I am doing this myself. I have got a $60 socket set from canadian tire and no inhibitions
« Last Edit: June 02, 2010, 11:49:18 PM by Jrama »
« Reply #9 on: June 03, 2010, 09:17:02 AM »
atta boy.
only tools really needed other than your standard set is a 13MM 12pt socket for the hub, and a 36MM for the axle nut.  it can be done in the drive way.
remember to antisieze all the bolts so next time you change em its quick!
YoungFluff03TJ
« Reply #10 on: June 03, 2010, 09:38:01 AM »
Yea man you dont want your tire to fall off while driving. that would just be terrible  -_-
if you need help gimme a call
ps. my socket set is shinier and the jeeps like shinier
« Reply #11 on: June 03, 2010, 09:44:28 PM »
its very easy .. and im sure there are more then enough people to give you a hand
my room mate learned how to change my second set and she didnt have to much trouble .. i just had to break the bolts free and she did the rest her self
then i just tightened everything a bit more after she was done
and you best off buying the socket for the axle because youll be useing it alot more often  ;D ;D
Offline X-Treme
« Reply #12 on: June 03, 2010, 10:07:28 PM »
atta boy.
You should NOT be putting anti-sieze on the bolts that hold the unit bearings in the knuckle. If anything, you should be using lock-tite. You REALLY don't want those bolts coming loose.
Also, if you ONLY have play side to side, and not up and down as well, chances are it's NOT a unit bearing. Check your steering linkage.
If it's a bearing, you should be able to feel play no matter where you put your hands. 12&6, 9&3, or anywhere in between, you should feel play with a bad bearing.
Offline CatSplat
« Reply #13 on: June 04, 2010, 01:11:15 AM »
The anti-sieze should be put on the mating surface between the unit bearing and knuckle, it'll make removing the assembly far easier in the future.
Jeep of Theseus
« Reply #14 on: June 04, 2010, 08:18:04 AM »
good luck busting that loose when you break an axle on the trail.........
