Author Topic: spring over help  (Read 4730 times)
PITBULL
spring over help
« on: June 16, 2010, 07:48:30 PM »
i need help im not sure i can bull crap my way threw this one my self i went to national and they said it would cost 10,000 for a spring over axel instale so i wont be takeing it to them
dose  anyone know how to do this and wanna make some money or trade i can spray bedliner in the tube of your jeep or your whole jeep so its like mine
PITBULL
Re: spring over help
« Reply #1 on: June 16, 2010, 07:49:25 PM »
and im not talking smack about national love the guys there and there service but thats just out of my price range sorry guys
Offline 2grand4u
« Reply #2 on: June 16, 2010, 07:54:32 PM »
10 000 for spring over was he kidding, spring over has to be the cheapest next to body lift you can do, weld on some spring perches, longer shocks, break lines and call it a day.
PITBULL
« Reply #3 on: June 16, 2010, 07:58:45 PM »
yeah i dont trust my welding and im more then willing to pay some one a few hundred bucks to do it for me ill help as much as a i can as i like to learn but need som help
« Reply #4 on: June 16, 2010, 08:33:14 PM »
is there a reason why you want to go spring over?  4" lift springs aren't that costly anymore...........
PITBULL
« Reply #5 on: June 16, 2010, 08:35:58 PM »
well i heard you get more clearence by doing it because you moving the mounts to the top so thats one reason and well every one has the 4 inch lift i wanna go a differetn route and try this way ....
« Reply #6 on: June 16, 2010, 08:42:08 PM »
gotcha
things to look out for;  the spring over lifts are notorious for axlewrap;  it happens on hills, in holes, etc.  what happens is the rear wheels 'hop'  and don't stay glued to the ground.....
the spring over also gives you about 5 - 6 inches of lift, and will kill driveline angles.   you will need a slip yoke on the rear;  or at minimum a tcase drop.  i run 4" springs and still need the drop........
in short, just the spring over is not a cheap lift; it will hit you in many other places!
the reason the 4" springs are so common is because it works really well :)  if you want something 'tall'  do a 4" spring under and do a 3" body lift.
maybe another question to address is what size tire do you want to run?  stock yj axles blow, and anything over 33s will be really sluggish and potential to break stuff is present. plus, a 6" lift on 33s will make ur tires look small.
anyways, just some ideas
Offline Shearcon79
« Reply #7 on: June 16, 2010, 08:52:35 PM »
Did they maybe think you were asking for a coil over install?  That would be a bit more work.
Green 94 4.0 YJ :
4.5" RE Extreme Duty
Tera-flex Super Short SYE
Drive Products CV Driveshaft
« Reply #8 on: June 17, 2010, 12:34:20 AM »
You cant blame national for the quote. A properly fabricated springover with a proper traction bar is a dirty job, and does approach that 80 plus hours of labor range to be done right.
Not to mention the parts involved like Alcan springs front and rear to try and avoid shitty flat springs that will fatique to fast.
For what in the end is a poor performing, outdated suspension that no one does anymore because it doesnt work very well.
« Reply #9 on: June 17, 2010, 07:45:46 AM »
Really? That's all there is to a spring-over? Gee, I should go get a YJ just so that I can do cheaper suspension mods.  :D
Why don't you tell us how many leaf sprung Jeeps you've owned and done spring-over conversions on. Let us know how they worked out in terms of road manners and real suspension performance on the trail.
« Reply #10 on: June 17, 2010, 07:53:45 AM »
You're joking right.  Spring-overs sound simple enough, but as stated above there are A LOT of other things to consider at the same time, especially the axle wrap issues in the rear.
Offline 2grand4u
« Reply #11 on: June 17, 2010, 08:19:07 PM »
i've helped with 2 and if you own a yj your not after suspension performance, for the wrap issue the is lots of very simple cheap solutions to that.
« Reply #12 on: June 17, 2010, 09:04:34 PM »
Anyone setting up any suspension without performance in mind is an idiot.
An axle wrap system is a complex link and shackle set that requires considerable fabricating and geometry knowledge.
They aren't cheap to buy, or have built unless you do it all yourself. Even then its a couple hundred for tube, bushings, shackle, joint, and crossmember material.
Even then they can be a gamble due to the rigs weight spring parameters.
Comparing ignorant back yard hack tactics to a properly done professionally fabbed and installed spring over is where you are missing the point.
Since its so easy and cheap, you should offer to do it for him.
« Reply #13 on: June 17, 2010, 09:07:55 PM »
Oh and I forgot out figuring out how to do the steering properly that is safe and strong
« Reply #14 on: June 17, 2010, 09:12:20 PM »
define 'performance'?????
would that be flexing, oh i dont' know, 1000+ on the RTI ramp?   cause i know 3 YJs in the club will do it......... but will your lil' TJ????????? we'll see at S&S i guess.
