Author Topic: Portable Air Compressor  (Read 7415 times)
Offline Bone206
« on: August 31, 2010, 05:20:27 PM »
If anyone is in the need for a portable air compressor for airing up, I was just at Costco today (the sarcee one) and they have the Bonaire DD25 there for $39.99. Here is a link to their website
 http://www.bon-aireindustries.com/products/detail.cfm?prodID=47
I thought it would be a pile'o'junk for $39.99, but it's actually pretty decent. It feels solid, comes with all of the hoses/hook-ups you need, comes with a bag,  and it's a 12V that hooks up directly to the battery. I just tried it out and aired up my 33" duratracs from 12 psi to 40 psi and it took just under 4 min. I tried the same thing with an ARB compressor a little while ago and it took 3:30.
Sure, there are faster/better ones out there, but for 40 bucks including all of the fixin's, it's a good deal.
Re: Portable Air Compressor
« Reply #1 on: August 31, 2010, 06:17:08 PM »
$39.99 is just what the doctor ordered for airing up after a run. Good find.
I'm surprised that you took that long to air up after a run with an ARB. My ARB compressor takes my 35's from 11 psi to 25 psi in about 90 seconds. ???
Offline Bone206
« Reply #2 on: August 31, 2010, 08:48:30 PM »
that's a good speed for sure.  For mine, it seems to go from about 15 psi to 30 psi in 2:30, then the last 1:30 is going from 30-40. Not bad for 40 bucks!
« Reply #3 on: August 31, 2010, 09:43:08 PM »
Damn I need a costco membership.
Offline Bone206
« Reply #4 on: August 31, 2010, 10:14:46 PM »
if you want one, PM me and I can help you out.
« Reply #5 on: September 01, 2010, 09:06:27 AM »
Dude, you already have a compressor, and a line on a second one for a very reasonable price. Your Ghetto-fab OBA system is gonna be ghtto-fabulos!
Offline CatSplat
« Reply #6 on: September 01, 2010, 11:14:08 AM »
Sounds great, thanks for the heads up!
Jeep of Theseus
Offline Knox
« Reply #7 on: September 05, 2010, 03:20:31 PM »
I see it comes with a presta valve, but what is the max psi its capable of? My road bike for example needs 90psi in the tires.
2003 TJ
Offline Bone206
« Reply #8 on: September 05, 2010, 04:24:47 PM »
It says it goes up to 150 and has an in line air gauge that gives real time readings. Although I haven't tried it that high, I used it on some mountain bikes this weekend and it worked great. Very quick fill.
« Reply #9 on: September 05, 2010, 06:29:15 PM »
I have Canadian Tire's "heavy duty" air pump for RV's. Its gauge goes to 150psi but I've never been able to get it past 40psi so I wouldn't let how far the gauge goes up impress you too much....
Offline Bone206
« Reply #10 on: September 05, 2010, 08:00:36 PM »
yeah, probably a good point. I've had it up to 65, but haven't had any need to go past that.
Offline Knox
« Reply #11 on: September 07, 2010, 08:45:05 AM »
was there any literature that came with the pump? stating what they rate the pump at for a max pressure? I saw on that site, they had max pressures listed for the Goodyear i7000 or something but not for that one.
2003 TJ
« Reply #12 on: September 08, 2010, 01:21:40 PM »
i have to ask...
what rig and tires are you running at 40psi? :eek:
nice find at Costco. i love Costco.
Offline Bone206
« Reply #13 on: September 08, 2010, 03:12:58 PM »
I'm running 275/70/18 duratracs on a JK and normally run 32 psi. I was just curious about the 40 for a while after reading some stuff on a JK forum for those E rated tires, but quickly decided that 32 is the magic number for me.
« Reply #14 on: September 08, 2010, 03:45:21 PM »
Those load E are stiff!
