Author Topic: it never ends....  (Read 3346 times)
Offline rt01
Re: it never ends....
« Reply #15 on: November 03, 2010, 03:55:10 AM »
I don't think I would try to tap them just replace them, and remember they're metric and the bolts you are using should be too!
 part #   6506 629aa for the 12mm
Offline jeepjones
« Reply #16 on: November 03, 2010, 03:57:17 AM »
Damn, you have some bad luck modding your rigs!
Offline GiS
« Reply #17 on: November 03, 2010, 06:47:02 AM »
Dont bother trying to drill and tap a nutsert, there isn't enough "meat" there. Your best bet is to replace the nutsert, or weld a nut inside the frame rail but I don't think the "windows" are large enough to get a good bead.
Yeah buddy, I've got some extended rear swaybar links, all yours! Just let me know when you want them...they aren't going anywhere.
Offline GiS
« Reply #18 on: November 03, 2010, 11:51:43 AM »
And yeah, like the other guy said...could be some mud in your frame. Check mine out  :o
Offline AV.NINE
« Reply #19 on: November 03, 2010, 06:08:52 PM »
Thanks anyways joey but too late. Modern had a set in stock for a good price.
I tried to tap the nutserts and failed. They came loose inside the frame. I had some hexicoil so I tapped the frame anyways and installed that. The bolts held and are tight. Kind of sketchy but I have a back up plan.
Note: the drivers side came out just fine.
Plan A - I have some bolts, and I'm going to weld them to a washer then weld a piece of metal (3"s) to that washer. Then tie the end of the bolt to some bailing twine and fish each one through the frame holes. That way alls I have to do is stick a nut on them.
Anyways, here's what she looks like all together:
Just needs an alignment to cure some death wobble.
Offline Knox
« Reply #20 on: November 03, 2010, 08:19:02 PM »
looks good, what do you have for axles in there?
2003 TJ
Offline AV.NINE
« Reply #21 on: November 03, 2010, 08:34:43 PM »
30/35
My real diffs are under construction...
« Reply #22 on: November 03, 2010, 08:41:34 PM »
Can you hold off on your alignment until your new axles are ready?
Offline Knox
« Reply #23 on: November 03, 2010, 08:52:49 PM »
what are you putting in there?
2003 TJ
Offline AV.NINE
« Reply #24 on: November 03, 2010, 09:36:12 PM »
No, they wont be done for 6 months give or take....
Front 9" with Dana 60 outters
Rear 9" with 14 bolt outters
« Reply #25 on: November 03, 2010, 11:47:01 PM »
are those 35   13.5
looking good .. thats alot of axle for a short arm
Offline AV.NINE
« Reply #26 on: November 04, 2010, 04:55:44 AM »
La will be coming when the wife allows
