Author Topic: Battery..?  (Read 3391 times)
Offline scott slade
  • Amboy... Route 66
Battery..?
« on: November 04, 2010, 09:16:03 PM »
Howdy,  05 TJ.... time for a new battery,   what do you recommend...?    ???
2005 LJ, Six Speed,
 16" Moab Rims
Offline 03Jeeper
Re: Battery..?
« Reply #1 on: November 04, 2010, 09:37:55 PM »
Canadian Tire Eliminator battery, we've always used them on our vehicles. Recently replaced mine with one. Good warranty.
Also has a good amount of CCA.
Offline JENSSEN
    • Racing For The Cure
Re: Battery..?
« Reply #2 on: November 04, 2010, 09:42:44 PM »
Interstate,..
www.racingforthecure.ca
Re: Battery..?
« Reply #3 on: November 05, 2010, 12:51:30 AM »
Interstate,..
Love Song...
Red Top Optima. It's served duty in 3 vehicles now with no hiccups.
Do you do a lot of winching? Have a powerful stereo with amps and subs? Do you sport a plethora of lights?
Usually a Canadian Tire battery that's rated for your vehicle will suffice. They've got a great warranty.
Re: Battery..?
« Reply #4 on: November 05, 2010, 07:22:24 AM »
I have a 875 CCA Canadian tire eliminator battery and it has been great for about 5 years now
Offline scott slade
  • Amboy... Route 66
Re: Battery..?
« Reply #5 on: November 05, 2010, 08:00:54 AM »
Tahnks,  Might go with the Canadian Tire option,  but who in town sells Optima...?   Thought I saw some years ago in  a Walmart... might have been down south...  Thanks for the help.
2005 LJ, Six Speed,
 16" Moab Rims
Offline raf2379
Re: Battery..?
« Reply #6 on: November 05, 2010, 08:16:08 AM »
national4wd and modern motors sell the optima batteries.
Offline dac
Re: Battery..?
« Reply #7 on: November 05, 2010, 09:13:28 AM »
Pretty sure Walmart still has them.
Re: Battery..?
« Reply #8 on: November 05, 2010, 09:16:35 AM »
Interstate off barlow SE sells and warranties Optima.
Modern and N4WD don't.  at least they claimed they didn't when I needed warranty service and had to take mine to Interstate.
i have a dead red top with 8 years of service and one with 3.5 years in for warranty.  new optimas since 2009 though only have max 3 year free replacement, no more pro-rated warranty.  only the red tops are 3 years, the rest of the lineup are less.
Re: Battery..?
« Reply #9 on: November 05, 2010, 10:39:04 AM »
Another option:
Odyssey's are expensive...but they offer an 8 year warranty. You can get them at AND batteries in the industrial park near where Modern and National are. Northstars are the same battery apparently - and they cost about the same too.
Offline scott slade
  • Amboy... Route 66
Re: Battery..?
« Reply #10 on: November 05, 2010, 11:00:49 AM »
Awesome,   Thanks Again..... 8)
2005 LJ, Six Speed,
 16" Moab Rims
Offline WagoneerXJ
  • Bagon Wagon!
Re: Battery..?
« Reply #11 on: November 05, 2010, 11:03:22 AM »
another vote for optima :) I'm runnin 4 of them with no problems. 3 reds and a yellow
84 Mustang GT-Built 351W 5spd
Offline JENSSEN
Re: Battery..?
« Reply #12 on: November 05, 2010, 12:20:43 PM »
Personally I have killed 3 Red Tops in less than 2 Years,. for winching and abuse the people at interstate reccommended I go to the yellow next time not the Red
Offline XJSteve
Re: Battery..?
« Reply #13 on: November 05, 2010, 12:48:01 PM »
Also, depending on the type of wheeling you do, the Optima batteries are sealed type so if you happen to tip over/flip over, the battery acid will not escape. In fact, you can run an Optima battery in any position you want e.g. on its side. Although an unlikely event that you end-up upside down and the acid drips onto you or other vehicle components, I run a Yellow Top Optima just in case.
'99 XJ 5.5 " Rubicon Express, 33" tires, AW4, 4.0, ARB bumpers front/rear, Warn 9000 lb winch, Rockhard rollbar, Optimal yellow top, Cobra CB, bushwacker flares, Safari snorkel; saving-up for a 3" body lift
Re: Battery..?
« Reply #14 on: November 05, 2010, 01:05:54 PM »
The CT Eliminators are sealed and come with a 3 year replacement and 9 year total warranty and are cheaper than optimas
