Author Topic: 4L jeep block  (Read 816 times)
Offline bdron
4L jeep block
« on: November 10, 2010, 07:04:55 PM »
can anyone tell me if the block on a 2000 TJ with 4L distributorless is the same block as any other jeep 4L block.
Offline WagoneerXJ
  • Bagon Wagon!
Re: 4L jeep block
« Reply #1 on: November 10, 2010, 09:24:14 PM »
should be the exact same as any 00-06 4.0L in TJ's, XJ's and WJ's
84 Mustang GT-Built 351W 5spd
Re: 4L jeep block
« Reply #2 on: November 11, 2010, 09:21:56 AM »
What Waggy said. Prior to that, as in 99 and down, there are changes to the water pump, water pump pulley, and alternator mounting boses and serpentine system.
Offline BlackAura
  • 2003 TJ Rubicon (Stock)
Re: 4L jeep block
« Reply #3 on: November 12, 2010, 01:09:28 PM »
The Cam Position Sensor (where the distributor used to be, on top of the oil pump drive assembly) is different...not sure what years.
I know 03 is different from 05-06.
03 sends a single position pulse with a ring and a sensor, 05-06 has some crazy setup that sends more position pulses I believe.
Not sure if 01 - 05 are all the same, I don't believe they are.
Edit:  I'm a moron, you're asking about the block, my bad.  Guessing you'll use the same computer / CamPS as you had before.
BlackAura (Kevin)
