Author Topic: What are your must haves in your wheeling tool kit  (Read 2526 times)
Offline silverfox
  • drawrof og nac enoyna
« on: December 15, 2010, 01:40:03 PM »
Ok so my wife is asking me about Xmas ideas.
I figure a half decent tool bag and some mandatory trail tools is a good way to go that was I am not transferring my tools back and forth from garage to jeep.
So now on to my question  (I know I know I have lots of questions)
What are your must haves in your tool kit for reasonable trailside repairs?
2018 JLU Lifted on 37's
Offline Knox
Re: What are your must haves in your wheeling tool kit
« Reply #1 on: December 15, 2010, 01:44:42 PM »
for small stuff, socket set, wire cutters/pliers, cable ties, good ratchet straps
first aid kit is nice too, at least bandages and stuff.
then there is always your recovery equipment, however I assume you've got the necessities since you've been out with the club already.
2003 TJ
Offline fug
  • Airdrie Pick n Pull
« Reply #2 on: December 15, 2010, 02:58:52 PM »
36 mm socket and breaker bar
12 point 13 mm socket
Both needed to changed out a front axle on the trail
Fug
TJ Rubicon
Offline Knox
« Reply #3 on: December 15, 2010, 03:14:43 PM »
i guess for winter wheeling a shovel is always good to have too
2003 TJ
Offline silverfox
« Reply #4 on: December 15, 2010, 03:19:13 PM »
Well I won't be winched up for the Jan 1 run but that will happen sooner rather than later.............this beast is only 8 days old in my possession.  I will have a recovery strap and the stock recovery points on the Rubi are more than adequate for this run (based on the list)  I have to find my recovery strap, but even if I don't I will have one for Jan 1.
The winch thing is a whole other kettle of fish, I was happy with my Superwinch on my '07 but then again I never really had it in any really taxing situations either.
Offline Knox
« Reply #5 on: December 16, 2010, 07:49:50 AM »
a tree saver is a good to have too if you'll be winching eventually. That may make a quick gift from someone :)
2003 TJ
« Reply #6 on: December 16, 2010, 07:53:07 AM »
Tree saver, snatch block, and a couple of shackles are all things you will want once you have a winch. Once you get a compressor, a tire plug kit and a nice big 2 inch rachet strap (for re-seating beads). An axe and maybe a sweep saw are good things to have in the Jeep as well.
Offline Pookapotamus
« Reply #7 on: December 16, 2010, 08:01:56 AM »
Trunk Monkey!
Offline Hi Lo Silver
« Reply #8 on: December 16, 2010, 08:06:31 AM »
Todd, I've seen another post of yours about a sweep saw. I'm curious? I've got 3 or 4 Swede Saws but I've never heard of a sweep saw.
Even did a google image search this morning and didn't come up with anything.
« Reply #9 on: December 16, 2010, 08:09:01 AM »
Same thing. I think they're actually supposed to be called a "bow saw"...but what do I know?
« Reply #10 on: December 16, 2010, 08:12:05 AM »
Yup, I should have gone to web search not image search. It showed up on teh second page of a search.
Thanks...just learned something new. :)
« Reply #11 on: December 16, 2010, 08:27:42 AM »
Two words
DUCT TAPE   ;D
« Reply #12 on: December 16, 2010, 08:30:23 AM »
two better words:  Gorrilla tape!  ;)
Offline Joel
  • Super Uber Web Wheeler
« Reply #13 on: December 16, 2010, 09:00:02 AM »
Two even better words: Rescue Tape ( http://www.rescuetape.com/videos/jeep-jamboree-3 ).
Been carrying this stuff for a few years now and have since repaired rad hoses, plugged a leaky radiator, and brake lines.
« Reply #14 on: December 16, 2010, 09:07:01 AM »
 :o :o :o i stand corrected!
