Author Topic: I Think Aussie Measuring Tapes are Screwy - OME 2"  (Read 5638 times)
Offline silverfox
  • drawrof og nac enoyna
« on: February 02, 2011, 08:16:27 PM »
First off thanks to Jay at Chanda Precision for doing an awesome job on getting my lift in and doing it on budget and right smack on time.
After much decision making and discussion and questions and queries I went with the OME 2" lift, HD Coils, Currie Front Lower Control Arm, Long Travel Shocks, Extended Brake Lines, extended bump stop,  and front and rear adjustable track bars all from Stan at Northridge (thanks Stan)
Interesting part is OME sells it as a 2" lift................I think them Aussie's are a little mixed up on there measuring
Before
After
Before
After
Before
After
Before
After
Overall before upping the tires to 35" it is up pretty much bang on 4 inches.  I didn't think a 4 difference in ride height would be that noticeable but it is very much noticeable. I am pretty sure I noticed a difference in ride with the HD springs as well, seems a bit more bouncy. Also it may have been my imagination but it also seemed a bit less stable solid on the road (I could feel it lean a bit more it seemed).  I am very happy at this point but now of course I am jonesing to get the tires on it..............looks a little like a skateboard at the moment :)
Can't wait to get it back on the trail and see how things work compared to before.
Thanks again Jay...............can't wait for the rubber and the winch.
« Last Edit: February 02, 2011, 08:19:28 PM by SilverFox »
2018 JLU Lifted on 37's
Re: I Think Aussie Measuring Tapes are Screwy - OME 2"
« Reply #1 on: February 02, 2011, 08:25:43 PM »
Ahhhhhhhhhhhhh....... our little guy is growing up......
« Reply #2 on: February 02, 2011, 08:38:58 PM »
Yup, it'll definitely lean more for sure - higher center of gravity. I think you'll be VERY happy with that lift.
Did you get coil retainers in the rear, and longer sway bar links?
Offline silverfox
« Reply #3 on: February 02, 2011, 08:48:58 PM »
Front and rear.........and yes
Offline AV.NINE
« Reply #4 on: February 02, 2011, 09:11:02 PM »
Drive it for a week and let the springs settle. Remeasure. I bet it drops an inch or so.
Offline silverfox
« Reply #5 on: February 02, 2011, 10:24:20 PM »
Dont mind if it settles a bit but hopefully it will not be more than an inch.  That is part of the reason that I went with the HD Coils
Offline AstraX
« Reply #6 on: February 03, 2011, 09:29:28 AM »
Looks Good Shawn. Makes you wonder why they don't just sell it as a 3"-4" lift....
« Reply #7 on: February 03, 2011, 10:47:43 AM »
Because Australia has lift laws.
« Reply #8 on: February 03, 2011, 01:07:37 PM »
Because they can't get the ride quality to where they demand of their products in that lift range.
Offline Tinkerer
    • My (OLD OLD OLD) website
« Reply #9 on: February 03, 2011, 06:12:32 PM »
They use those Texas inches... and we all know everything is bigger in Texas!  Looks good...
LT285/75R15 Trxus MT's
VE6PDB - usually on VE6RYC
Offline JJonesee
« Reply #10 on: February 21, 2011, 03:58:41 PM »
Yes...  Its a Texas thing.
It will settle - all of the OME stuff does.  Its part of the progressive rate they build into the coil.  Great products designed for more abuse than you can imagine.
Fabtech used to be the worst - the SO Cal crowd is alot of high speed whoops, so the coils are always 2-3" higher than labled.
At the shop I used to work at in Texas, I swear we had a berm behind the shop - if customers complained it was too high - we told them to take it at about 20km/hour.  The rapid cycling caused the lift to settle faster. (this is not a recommendation by the way - however please film if you do)
06' Rubicon LJ
52' M-100
82' Scrambler x 3
Offline silverfox
« Reply #11 on: February 21, 2011, 08:12:57 PM »
Two wheeling trips and she has settled about a half inch.
