Author Topic: Decal Removal  (Read 3175 times)
Offline FirstTimer
  • Gettin there!
Decal Removal
« on: April 06, 2011, 04:46:51 PM »
Anyone have any tips or advice on how to remove stock decals?
02' Black TJ Apex on 33s, 2.5"  OME HD lift, Currie JJ CA on all four corners, 4:10 axles, Husky-Liner Rear Swing-Away Bumper and Bushwackers Flat Flares.
Offline Jeepless
Re: Decal Removal
« Reply #1 on: April 06, 2011, 04:58:33 PM »
Use a heat gun and your fingers. NOT a razor blade. I've taken off hundres of decals and pinstriping. If there is glue left on the vehice when done just use a decal remover(3m) if you have it or a little thinner on a rag to wipe off the glue. Wash the area with water when done.
Offline TL-Iguana
Re: Decal Removal
« Reply #2 on: April 06, 2011, 06:07:57 PM »
Bacon grease may work as an easing agent.
Just heat them up slowly, not too much heat in any one spot or you can cause your paint to bubble. Just do it slowly, and peel them off carefully. Dental floss works too to remove moulding thats 2 sided taped on.
'01 XJ on 35s, '11 Jk DD
Offline vantagetes
  • Edmonton Trail Rated
Re: Decal Removal
« Reply #3 on: April 06, 2011, 06:24:09 PM »
Kyle I like your decals, makes it something besides just another black TJ.
Offline w squared
  • Keamy Hungry!
Re: Decal Removal
« Reply #4 on: April 06, 2011, 07:05:52 PM »
A platic putty knife from Cambodian Tire, a hair dryer, and a bottle of goo-gone. Make sure the area is clean before, and wash it with soap and water afterwards.
Offline specialk
Re: Decal Removal
« Reply #5 on: April 06, 2011, 08:12:40 PM »
sand blaster or disc grinder
04 TJ Rubi
Offline silverfox
  • drawrof og nac enoyna
Re: Decal Removal
« Reply #6 on: April 06, 2011, 08:52:04 PM »
2018 JLU Lifted on 37's
Offline TL-Iguana
Re: Decal Removal
« Reply #7 on: April 06, 2011, 11:24:13 PM »
Best solution to also remove alberta pinstriping, road paint splatter, and all other stickers but pink. Pink stickers require much much more to remove. You are not ready young padawan.
Offline .:.Dingman.:.
Re: Decal Removal
« Reply #8 on: April 06, 2011, 11:27:49 PM »
how I used to do it is:
1. peel off most of the decal using a heat gun don't get it too hot!!!
2. use paint stripper or goo-gone
3. wet sand it but don't go too far
4. buff it
5. enjoy it.
Dingman
Offline WhiteOut
Re: Decal Removal
« Reply #9 on: April 06, 2011, 11:28:17 PM »
Heat and goo gone for the residue.
Or just wait for a freezing cold day and use an ice scrapper. >:(
Offline yyc_tbird_sc
Re: Decal Removal
« Reply #10 on: April 07, 2011, 01:02:42 AM »
screw the heat gun, scraping, and peeling. Go over to C-Max (right next to the NAPA in the NE near the Hooters), get a rubber eraser wheel for use with a drill. Use it exaclty as it sounds. Works exactly like an eraser. Use a little brake clean or other solvent to clean up any left over glue residue. I used these things years ago when I worked in a body shop, and have sworn by them since. I've even used them to strip entire decal packages off of fleet emergency vehicles.
Wear safety glasses. It works like an eraser does with a pencil and you get little flakes of rubber all over. If you have alot of decal to remove, I'd suggest "garage clothing". Also, when they wear down to the line, don't think you can keep using them past that point as you'll quickly find the plastic/metal plate in the middle for support.
-'97 Ranger w/ 4" lift, 33" MTZ's, 4.56's, and some new sheet metal
-'89 Thunderbird SC - 285HP, 392ft/lbs [email protected]
Offline Knox
Re: Decal Removal
« Reply #11 on: April 07, 2011, 07:45:50 AM »
in the past I just picked a warm day in the summer, all the decals I wanted to remove peeled off fairly easily with some pressure from a fingernail. Got more to do this summer though. Too cheap for a heat gun :P
2003 TJ
"Your TJ has the aerodynamics of a brick"
"if you lose the stick, chances are you'll lose the jeep......"
Offline LLYJ
  • carport ghetto fab
Re: Decal Removal
« Reply #12 on: April 07, 2011, 11:54:29 AM »
Buy and use an eraser wheel - I had a ton of decals all over my jeep and scraping and goop remover worked on some but removing desert baked ones resulted in damage to my paint underneath (just took the shine off but still looked crappy)- the eraser wheel takes the decal and the glue off very well with zero damage.  I've taken about 10-15 decals and still have half of the eraser wheel left - they are well worth the invesment - just watch the heat, if it gets too hot it just pushes melted glue around instead of taking it off.
I found mine at Napa for about $28 - seemed expensive so I waited and sure enough I found one in the Golden Napa on sale for half price - after using it I would pay 28 bucks for another one if I needed it.
51 Willys CJ3A - V6, SM420, T18, D44/27 lockers
93 YJ, starting to see light at the end of the carport
98 ZJ, 5.2l - DD with too many go go gadgets
05 Dodge 2500HD hauler
Offline FirstTimer
  • Gettin there!
Re: Decal Removal
« Reply #13 on: April 07, 2011, 02:58:33 PM »
Thanks for all the advice!
And don't worry Jason, I am only removing a few of the APEX decals to free up some space for some better ones!  The hood decal and pin stripping is staying!
Offline JackstandJohnny
  • where Jeeps go to die
Re: Decal Removal
« Reply #14 on: April 07, 2011, 04:08:36 PM »
correct me if i'm wrong but don't those stickers add, like, 5 hp? seems stupid to give up hp!
are the ones you adding give you an additional 1ohp?
