Author Topic: how much lift  (Read 3969 times)
Offline owen2
how much lift
« on: April 10, 2011, 06:55:09 PM »
Hi I just bought a jeep a 94 yj for 500 bucks. And was wondering how much lift I need to fit a set of 36 inch tires
Offline Knox
Re: how much lift
« Reply #1 on: April 10, 2011, 08:05:40 PM »
are you willing to cut the fenders? are you planning on upgrading the axles?
if not (fender cutting) whats it take guys like 4"Coil + 1.5" BL?
2003 TJ
Re: how much lift
« Reply #2 on: April 10, 2011, 08:56:21 PM »
Coil lift on a YJ  :o :o
To fit 36s on a YJ you are probably going to need around 4-4.5" of suspension lift, plus I would install 0.5" shackle lift and then 1" body lift.  In addition for good measure I would look at installing TJ flares as well as they open up the wheel wells for more room
Re: how much lift
« Reply #3 on: April 10, 2011, 10:11:25 PM »
silly knox,  coils on a TJ yo.
leafs on a YJ lol
i ran 4.5" rubicon express springs/shocks and a 2" body lift.  i also have TJ flares and hacked back the tub in the rear to clear em.  ran 36" iroks with no issues.
your axles on 36s will not be happy.  i kept eating front end components...... your rear D35 will not be happy either.......
so ya, it is not a big deal to fit them, but your axles will need to be addressed.........  at least, i think so.
i dropped down from the iroks to 35s because i got sick of breaking the D30... rears an 8.8. it holds up ok.
good luck with your 500$ jeep!  score!
Offline LEMON-AID JAY
  • Bad a$$ zj owner
Re: how much lift
« Reply #4 on: April 10, 2011, 10:47:08 PM »
I can get you some high clearance fenders fit 35" tires on stock suspension.
http://www.tntcustoms.com/Jeep_Tube_Fenders_YJ.aspx
http://www.tntcustoms.com/yjcornerarmor.aspx
« Last Edit: April 10, 2011, 11:02:50 PM by LEMON-AID JAY »
E-mortal customs
Www.e-mortalcustoms.com
3-2808 Ogden road s.e.
E-mail. [email protected]
Phone 403-265-6669
E-mail @ [email protected]
for all your 4x4 needs
www.piratesof4x4.com
Re: how much lift
« Reply #5 on: April 10, 2011, 11:06:23 PM »
The question is not really "What do I have to do to fit 36's?"
the question is "What do I have to do to run 36's without breaking things all the time..."
OR
perhaps the question is "What size tire can I run within the budget I have..."
Offline mike s
  • Good times!
Re: how much lift
« Reply #6 on: April 11, 2011, 07:43:44 AM »
sounds like the tires are worth more than the YJ...unless your 33's are holding you back, why bother?
oldEnuff2NObetter
but still can't help myself
Re: how much lift
« Reply #7 on: April 11, 2011, 12:46:27 PM »
Why whenever someone asks about tire size, the topic always get hijacked and everyone starts talking about axles.   ???  He just asked a simple question amount lifts, geez
Re: how much lift
« Reply #8 on: April 11, 2011, 12:56:55 PM »
if i paid 500 for a jeep, i would sawzall that thing to fit 36's with minimal lift.
Offline owen2
Re: how much lift
« Reply #9 on: April 11, 2011, 03:10:18 PM »
Well not to keen on the sawzzall idea the body is in great shape so a 4" and a 3"
Re: how much lift
« Reply #10 on: April 11, 2011, 04:18:11 PM »
i would not do more than 1" body and if i realllllly had to, 2" most. Definitely not 3".
When i said sawzall, you could flat fender it, cut wheel well openings bigger. Run TJ flares in the rear. You can sawzall/cut and still make it look really good.
Re: how much lift
« Reply #11 on: April 11, 2011, 04:52:31 PM »
they will fit just fine at 4" and 2" bodylift.
you can hack the rear fenderwell out to clear 36s. in fact you can probalby do it on 5" of lift.  even a 3 1/2" ilft and 1" bodylift (what i wish i had) check out my jeep. you can't even tell i cut anything.
even at that lift hieght of 4" susp and 3" body, you might hit the rear tub at flex.
Offline Knox
Re: how much lift
« Reply #12 on: April 11, 2011, 07:17:17 PM »
i can't even say that it was late... 8:05pm...
but my numbers were close :P
2003 TJ
Offline owen2
Re: how much lift
« Reply #13 on: April 13, 2011, 02:22:28 PM »
What about doing an soa. Is it a better op and is it any cheaper
Re: how much lift
« Reply #14 on: April 13, 2011, 02:39:49 PM »
yes and no.
either way you have to add new shocks, so thats an expense for both SOA and SUA.
if you go spring over axle (SOA) you are going to run into axlewrap issues most likely, and definitly will be taxing your driveline angles. even at 4" a tcase drop is necessary! (usually)   also, axlewrap sucks.  you also have to weld the new spring perches in too.  not a biggie, if you're a welder i guess!
doesn't mean its not an option.... but there are plenty of 4" kits out there reasonably priced........
