Author Topic: Lost 4 high  (Read 1211 times)
Offline trappertrev
  • Winch Wench
Lost 4 high
« on: May 10, 2011, 10:55:07 PM »
I lost 4 high in my 99 xj last fall. 2 and 4 low still work fine but I thought I should have a look at it. What t case options do I have if I need to replace this one.
Offline .:.Dingman.:.
Re: Lost 4 high
« Reply #1 on: May 10, 2011, 11:06:04 PM »
You can swap a 242,231,241. I do believe.
Dingman
Offline trappertrev
  • Winch Wench
Re: Lost 4 high
« Reply #2 on: May 11, 2011, 11:03:31 AM »
Difference would be gearring?
Offline TL-Iguana
Re: Lost 4 high
« Reply #3 on: May 11, 2011, 04:48:18 PM »
231 and 241 are for part time 4x4 operation only, slippery, loose road surfaces.
242 will have a 4x4 full time option so you can run it on dry pavement without undue stress to the drivetrain.
'01 XJ on 35s, '11 Jk DD
Offline trappertrev
  • Winch Wench
Re: Lost 4 high
« Reply #4 on: May 12, 2011, 12:57:39 PM »
So out of the 231 and 241 is one stronger then the other?
Offline TL-Iguana
Re: Lost 4 high
« Reply #5 on: May 13, 2011, 12:27:54 AM »
Cant tell you for sure but everything Ive read and heard, the 231 is a stronger transfer case.
Offline trappertrev
  • Winch Wench
Re: Lost 4 high
« Reply #6 on: May 13, 2011, 03:40:04 PM »
Thanks for the info. It has 231 so if needed I'll rebuild that one.
