Author Topic: Door lights still on with fuse pulled  (Read 2280 times)
Offline BlackAura
  • 2003 TJ Rubicon (Stock)
« on: May 11, 2011, 08:20:36 PM »
So...was thinking of pulling the doors off, and went to pull the door light switch defeat fuse.
The fuse was already pulled :/
Putting a 10amp in, and/or removing the 10amp fuse, doesn't seem to change how the lights work.  If a door is open, the lights are on.
For now I'm thinking I'll just pull the bulbs, eventually I guess I'll install a switch or something.
Anyone have any ideas?  2003 Rubicon.
BlackAura (Kevin)
Re: Door lights still on with fuse pulled
« Reply #1 on: May 11, 2011, 09:03:40 PM »
Offline Slewfoot
« Reply #2 on: May 11, 2011, 09:07:49 PM »
Are you sure you have the correct fuze?  If you have the correct fuze...and it doesn't affect anything...somebody's been messin' with the wiring.
Offline TJ Sparky
« Reply #3 on: May 11, 2011, 09:34:51 PM »
Why do you Wrangler guys need so much help?
LMAO!
If you are looking for a cheap hobby that will get you out into the woods, collect rocks or bird watch........don't buy a Jeep.
Offline scott slade
  • Amboy... Route 66
« Reply #4 on: May 11, 2011, 09:52:20 PM »
Fuse pulled on my 05 and worked great...  should not be adifferance between the two years....just keep pulling until the light goes out...   ::)
2005 LJ, Six Speed,
 16" Moab Rims
Offline Knox
« Reply #5 on: May 11, 2011, 10:02:25 PM »
I pulled fuse 4 last night (2003) (took the doors off last night) worked great for me. The only thing I noticed was the head light chime seems to be grouped so I really have to keep in mind to turn off the driving lights.
http://www.jeepforum.com/forum/f9/faq-how-do-i-turn-off-dome-lights-doors-removed-416001/
2003 TJ
« Reply #6 on: May 11, 2011, 10:05:24 PM »
Or ya could sell the Wrangler, and get yourself into an XJ!
No need to pull fuses or spend money on harnesses, as our doors dont come off! Thats what windows are for!
Offline scott slade
  • Amboy... Route 66
« Reply #7 on: May 11, 2011, 10:09:37 PM »
Tj's get the girls, and XJ's get the groceries on the way to soccer......   lol.....   I know I'm going to get it for this comment...!!!   Just kidding gentlemen... ;D
2005 LJ, Six Speed,
 16" Moab Rims
Offline Knox
« Reply #8 on: May 11, 2011, 10:18:33 PM »
Tj's get the girls
Yeah they seem to attract girls alright... probably 90% of the TJ drivers I saw out today were female...
2003 TJ
Offline scott slade
  • Amboy... Route 66
« Reply #9 on: May 11, 2011, 10:28:47 PM »
That is true, but dare I say they rarely go off road with them on purpose....  no offence ladies...!!!!     anyway.  .good luck with the fuse pulling....  keep smiling... ;D
2005 LJ, Six Speed,
 16" Moab Rims
Offline BlackAura
« Reply #10 on: May 12, 2011, 11:46:37 AM »
Yep...pretty sure.
I'm a little worried about the wiring now.  Where are my interior lights getting power from, and is it fused?  Guess I'll pull the fuse box out and trace the wires back, see where the proper wires go....then pull the passenger speaker cover and see what's powering the light.  :-\
Thanks for checking some other TJs guys, I was a little confused when reading the fuse needed to be pulled, and mine wasn't in there to begin with.
Also, you XJ guys are just jealous you can't go topless!  :D
« Last Edit: May 12, 2011, 11:48:29 AM by BlackAura »
BlackAura (Kevin)
Offline scott slade
  • Amboy... Route 66
« Reply #11 on: May 12, 2011, 12:33:31 PM »
I do have a set of those little spring clips made to hold the button in while the doors are off if you want them.....  My fuse pull works, so i don't need them... let me know... 8)
2005 LJ, Six Speed,
 16" Moab Rims
Dracitamo
« Reply #12 on: May 12, 2011, 12:53:59 PM »
My electrical knowledge sucks so I can't offer any advice.. but..
Quote
Maybe not... but camping, we are warm and dry, and when you are soaking wet and cold because your tent leaked, we have plenty of room for your gf to come warm up.  ;D
And the next time you do a swap, you know you will be calling on us to help you get new diffs picked up.  8)
Offline Knox
« Reply #13 on: May 12, 2011, 01:32:45 PM »
Yep...pretty sure.
If you want to take a drive to the SW, feel free to swing by (PM for address if interested) and we can compare the two 2003s side by side and see if there is something up with your fuse panel. But as far as I can tell our panels should be identical. As a curtesy I will snap a picture tonight and post it for you.
2003 TJ
« Reply #14 on: May 12, 2011, 01:51:07 PM »
http://www.quadratec.com/products/13029_200.htm
or
http://www.quadratec.com/products/13029_100.htm
Hey don't put else YJ guys into this category.  We just have to pull the wire connector off from the door
