Toggle navigation
Login
Register
Welcome,Guest
1 Hour
1 Day
1 Week
1 Month
Forever
4x4 Related Groups
Tech Talk
4 Lug Spindle Socket - DANA 44
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: 4 Lug Spindle Socket - DANA 44 (Read 1700 times)
Shearcon79
Budget Lift
on:
July 27, 2011, 10:24:04 PM »
Where do I get one of these in Calgary?
I tried Crappy Tire but they don't have the right size. Instead of driving all over the place I thought I would ask.
Logged
Green 94 4.0 YJ :
4.5" RE Extreme Duty
Tera-flex Super Short SYE
Drive Products CV Driveshaft
vantagetes
That CB Yapper
Edmonton Trail Rated
Re: 4 Lug Spindle Socket - DANA 44
Reply #1 on:
July 28, 2011, 12:08:40 AM »
I use a 36mm shallow and a strong arm. Put the strong arm on a 45* angle from the floor and then give it one good stomp, works every time!
Logged
FiEND
Talks waaay too much!
Wrecking Ball
Reply #2 on:
July 28, 2011, 02:09:40 AM »
auto value and canadian tire shawnessy has em.
Logged
raf2379
That CB Yapper
Reply #3 on:
July 28, 2011, 06:17:44 AM »
auto value, parts source, canadien tire, napa. they all have them
Logged
Shearcon79
Budget Lift
Reply #4 on:
July 28, 2011, 06:52:45 PM »
I found the right size at Autovalue. thanks
Logged
Green 94 4.0 YJ :
Shearcon79
Budget Lift
Reply #5 on:
July 28, 2011, 06:53:36 PM »
Now I can't get the damn spindle off. Rusted to the knuckle. Any ideas?
Logged
Green 94 4.0 YJ :
raf2379
That CB Yapper
Reply #6 on:
July 28, 2011, 07:06:00 PM »
a big heavy rubber mallet, i got mine from princess auto, its soft rubber and big. whack! whack! works everytime.
http://www.princessauto.com/workshop/hand-tools/striking-tools/mallets/2920305-32-oz-rubber-mallet
Logged
cLAY
Reply #7 on:
July 28, 2011, 09:27:56 PM »
You don't want to pound on the spindle directly as you can damage the threads or even make it egg shapped. Put the two "nuts" back on and jam them against each other and wack on them. If you have to wack REALLY hard try to use wood or something. You may need to clean the nuts up after with a file. I have an extra set I use just for that purpose.
Logged
Shearcon79
Budget Lift
Reply #8 on:
July 28, 2011, 10:49:52 PM »
Got it!!
Put the two nuts back on and hooked a gear puller on them and the shaft for tension while I whacked it with my big mallet. I also liquid wrenched the hell out of it and let it sit for a while. I banged on the upper ball joint and that is when the spindle started to move. As it came apart I increased tension on the puller and worked it out evenly. What a struggle
Thanks for the tips!
Logged
Green 94 4.0 YJ :
Print
Pages: [
1
Go Up
« previous
next »
4x4 Related Groups
Tech Talk
