Author Topic: 4 Lug Spindle Socket - DANA 44  (Read 1644 times)
Offline Shearcon79
« on: July 27, 2011, 10:24:04 PM »
Where do I get one of these in Calgary?
I tried Crappy Tire but they don't have the right size. Instead of driving all over the place I thought I would ask.
Green 94 4.0 YJ :
4.5" RE Extreme Duty
33x12.5 MTZ's on 15x8 Black Steelies
Tera-flex Super Short SYE
Drive Products CV Driveshaft
Swing-away Tire Carrier/Bumper/Hitch
Found D44's out of a Waggy...Just need to build them
Offline vantagetes
  • Edmonton Trail Rated
Re: 4 Lug Spindle Socket - DANA 44
« Reply #1 on: July 28, 2011, 12:08:40 AM »
I use a 36mm shallow and a strong arm. Put the strong arm on a 45* angle from the floor and then give it one good stomp, works every time!
Offline FiEND
  • Wrecking Ball
« Reply #2 on: July 28, 2011, 02:09:40 AM »
auto value and canadian tire shawnessy has em.
1Wide2High
ILV2FRT
'97 TJ [sold]
'17 JK Rubicon
Offline raf2379
« Reply #3 on: July 28, 2011, 06:17:44 AM »
auto value, parts source, canadien tire, napa. they all have them
Offline Shearcon79
« Reply #4 on: July 28, 2011, 06:52:45 PM »
I found the right size at Autovalue. thanks
Green 94 4.0 YJ :
Offline Shearcon79
« Reply #5 on: July 28, 2011, 06:53:36 PM »
Now I can't get the damn spindle off. Rusted to the knuckle. Any ideas?
Green 94 4.0 YJ :
Offline raf2379
« Reply #6 on: July 28, 2011, 07:06:00 PM »
a big heavy rubber mallet, i got mine from princess auto, its soft rubber and big. whack! whack! works everytime. http://www.princessauto.com/workshop/hand-tools/striking-tools/mallets/2920305-32-oz-rubber-mallet
Offline cLAY
« Reply #7 on: July 28, 2011, 09:27:56 PM »
You don't want to pound on the spindle directly as you can damage the threads or even make it egg shapped. Put the two "nuts" back on and jam them against each other and wack on them. If you have to wack REALLY hard try to use wood or something. You may need to clean the nuts up after with a file. I have an extra set I use just for that purpose.
Offline Shearcon79
« Reply #8 on: July 28, 2011, 10:49:52 PM »
Got it!! ;D
Put the two nuts back on and hooked a gear puller on them and the shaft for tension while I whacked it with my big mallet. I also liquid wrenched the hell out of it and let it sit for a while. I banged on the upper ball joint and that is when the spindle started to move. As it came apart I increased tension on the puller and worked it out evenly. What a struggle >:(
Thanks for the tips!
Green 94 4.0 YJ :
