Author Topic: open differential auto vs 5 speed - are they the same??  (Read 2776 times)
Offline indycalgary
« on: July 30, 2011, 10:01:10 AM »
Can i use a 8.25, 3.07 ratio rear diff in my 5 speed manual trans jeep cherokee sport if it came out of a jeep with a automatic transmission.  I am assuming i can?
And how will it effect my 4x4 ability?  Currently my diff is LSD.
Re: open differential auto vs 5 speed - are they the same
« Reply #1 on: July 30, 2011, 10:02:24 AM »
the 3.07 is the problem 8)
Offline indycalgary
Re: open differential auto vs 5 speed - are they the same??
« Reply #2 on: July 30, 2011, 10:47:19 AM »
i have no idea what u r talking about???? wow !!!!
Offline Black Betty
« Reply #3 on: July 30, 2011, 10:53:26 AM »
As long as the front and rear gear ratios match, you can do whatever you wish.  I have doubts that a 3.07 ratio came from an automatic, but as my wife, I'm not always right!
Stupid hurts
« Reply #4 on: July 30, 2011, 12:29:06 PM »
What!!!!!? Adrian, you confuse me.
3.07s should have been out of a standard transmission (AX-15) Jeep.
Jeep XJs came in several standard gearing ratios:
3.07:1, manual transmission, I6 engine.
3.54:1, automatic transmission, I6 engine with Dana 44 rear differential.
3.54:1, manual transmission, I4 diesel engine with Dana 35 rear differential.
3.55:1, automatic transmission, I6, V6 engines; manual transmission, I4 engine.
3.73:1, automatic transmission, I6, Tow Package, UpCountry Package.
4.10:1, manual transmission, V6; automatic transmission, I4 engine.
4.56:1, automatic transmission, I4, offroad or tow package.
Offline Black Betty
« Reply #5 on: August 03, 2011, 08:23:51 PM »
Sorry, stupid iphone, i ment as my wife says, i'm not always right!
And i had doubts that the 3.07 ratio came in an automatic, they are slow enough in my I6 yj manual, let alone an auto!
« Last Edit: August 03, 2011, 08:25:35 PM by Black Betty »
Stupid hurts
« Reply #6 on: August 03, 2011, 10:08:57 PM »
Indy... usually the gear ratio in differentials on a stock XJ are different for auto or manual tranny.
You will have 3.07 gear ratio in most  stock XJ with manual tranny and 3.55 gear ratio in most XJ with automativ tranny.
So your question is wrong... Basically if your 8.25 came out of an automatic tranny it should have 3.55 gear ratio and NOT 3.07.
So your XJ has 3.07 gear ration and you are trying to put in a rear axle with 3.55 gear ratio. The front gear ration should match the rear gear ratio in your diffs/axles.
So... No it willl not work
Offline apeman
  • not as grumpy
« Reply #7 on: August 04, 2011, 04:26:36 AM »
Okay this is getting absolutely redundant...Stupid actually.  Go get an 8.25 rear end, from a manual trannied xj, swap the thing in. If it has ABS sensors , so what, leave em there, cut them off...voila. open carrier and matching gears...there is your cheapest and easiest option. End of story.
Obviously you dont have the capacity to understand what has been said over and over. If you figure you need a ltd slip for real 4wd, then you need to search "lockers"..crappy jeep ltd slips rarely work worth crap, get over it.
If you havent figured out how to remove a rear axle from your XJ (yup, thats the model designation for your jeep!) from what we have said, or what a haynes manual can provide, you serve zero purpose to this club whatsoever.
If you bought a rear end from an auto XJ (theres that word again) , take it in and have your ring and pinion swapped, and expect to pay to have it done.
Or keep posting, theres always someone here to hold your hand, i just dont know how much more we can dumb it down for ya. ::)
Getting grumpier every day.
« Reply #8 on: August 04, 2011, 08:46:31 AM »
Really man?
The dude is a newby and does not understand...
« Reply #9 on: August 04, 2011, 08:57:40 AM »
....getting grumpier every day.......
That about sums it up!
Offline indycalgary
« Reply #10 on: August 04, 2011, 09:14:20 AM »
Wow Harsh people on here ...... yes i understand but there is no way to delete this post...... my question was answered long ago (when ur desperate one tries anything).
But for your info there are no 8.25/3.07 trannys out there (well other than the ones i was promised and then told its gone - 3 times) ... unless u want to spend $600... from want i find on this site thats way too much!
« Last Edit: August 04, 2011, 09:40:47 AM by indycalgary »
Offline NUXJR
« Reply #11 on: August 04, 2011, 09:43:46 AM »
Wow Apey!!!  See yur people skills are still the same :D.  Need to start getting more fibre in yur diet or something :P.
Now seriously folks...I've known Aaron since I built my first Jeep(he even helped me a fair bit).  Good guy, but till ya get to know him can seem a bit edgey at times.  Usually means well but could use some coaching with his people skills ::).
Let's all be friends, k?
« Reply #12 on: August 04, 2011, 10:07:35 AM »
when things are sold at severe discount, it is best to buy, and not hem and haw.  i had what you needed. for cheap.  you weren't sure and sat on the fence.  someone came with cash and took it.  !
to many times people say 'yea i'll take them' only to be told (after the seller 'holds' the parts for a week) that 'something' comes up.  i've got a garage full of parts that are testaments to this ;)
if you want it, go buy it.
« Reply #13 on: August 04, 2011, 11:07:56 AM »
« Reply #14 on: August 04, 2011, 11:15:49 AM »
Wow Harsh people on here ...... yes i understand...
Then please stop posting about your rear end issues, same posts, same questions since your first one back in May. You probably just need a bearing or tighten your lug nuts or something.
Don't worry about LSD, drugs are bad !  :)
