Author Topic: never build a ZJ......  (Read 58532 times)
Offline Pookapotamus
Re: never build a ZJ......
« Reply #90 on: October 14, 2012, 05:57:32 PM »
holey red neck rti ramp! goes great with the sleazy Z!
Offline Gorg
« Reply #91 on: October 14, 2012, 09:46:18 PM »
Looks sick, and it would look even better if it was stretched   ;)
'15 Ram 1500 Express
'06 Audi A4 B7 quattro
'08 Jeep XK Limited
'06 Jeep TJ Sport
'99 Jeep XJ Sport
Offline JackstandJohnny
  • where Jeeps go to die
« Reply #92 on: October 14, 2012, 10:04:53 PM »
gonna 'stetch' it to 109" its at 108 right. why? becuase at full stuff or semi full stuff i know if i crank the wheel there could be issues.
any more and i might as well have started with a regular cab shortbox truck ;)
Offline TL-Iguana
« Reply #93 on: October 15, 2012, 07:03:18 AM »
nice build johnny :) not a yj which is sad, because Halloweeen is coming and that made a great costume on you ;)
However it looks like you need to push the real axle out more as it seems like its too close to the front in those pictures... if your lookin to stretch it that is.
'01 XJ on 35s, '11 Jk DD
« Reply #94 on: November 01, 2012, 09:09:48 PM »
decided to stay with 33s for now.  maybe in the future when i get gears and lockers. for now think i'm gonna stay on the 33s.
couple other things coming down the line........ gonna do an efan conversion, some hood louvres and possibly some long arms??? ???
Offline heep-a-lop
  • EMF WHORE
    • EMF Rod Ends And Steering Components
« Reply #95 on: November 02, 2012, 12:08:53 PM »
if u do long arms let me know mine might be done by then....    e fans are easy if u can find a 5.9... if not i got my rad out and am planning on building my own setup in the near future....
Offline cLAY
« Reply #96 on: November 05, 2012, 09:02:11 AM »
Better rethink that one. Efans for a 5.9 are super hard to come by and if you do find one they are well over $500. I just converted a 5.9 to a mechanical fan using fan and shroud from a 5.2 for that reason.
Taurus fan is WAY cheaper and just as easy.
« Reply #97 on: November 05, 2012, 09:11:20 AM »
I though of a niner fan but to costly. Unless your niner fans for sale clay ;).
I have a couple Taurus fans in the garage :). Have a habit of bringing them home when I goto pnp!
Offline cLAY
« Reply #98 on: November 05, 2012, 09:21:29 AM »
I could sell you the fubard one I just pulled out...... 1/2price!
Offline cLAY
« Reply #99 on: November 05, 2012, 09:23:38 AM »
The Taurus fan I mounted into my '93 was pretty easy. I removed the original 5.2 shroud and then mounted the Taurus fan inside it with self drilling screws. Took some trimming of the the shroud and fan but was pretty simple.
« Reply #100 on: November 05, 2012, 09:31:28 AM »
hey Clay could you fire me a PM with the details on how you wired up the taurus fan? or post em? i'm trying to find an all in 1 controller type thing like this --> http://www.dccontrol.com/relay_controllers.htm
but i don't know if that includes a temperature sensor unit, or what else i'd need. i think i also need a 70A fuse to right?
at least i admit i suck with electrical :(
Offline cLAY
« Reply #101 on: November 05, 2012, 09:39:25 AM »
I only used the high speed setting on my fan. Power to it is fed a continous duty solenoid, like what you see inside a Warn winch solenoid pack. The solenoid is controlled by a cheap Flex-a-lite controller with a probe shoved into the rad fins.
Lately the controller has not been working right so I may replace with a temp probe in one of the rad hoses. I would lose my adjust ability though. The Flex-a-lite controller has an adjustemnt screw on it to adjust kick in/out up and down. A probe would just be at set temp.
I also have a 3 way switch on the console for the fan.  Off/Force on/Auto
Offline heep-a-lop
  • EMF WHORE
« Reply #102 on: November 05, 2012, 10:01:24 AM »
see my thoughts where to build a shourd basically outta a piece of 16 guage steel that wold slide into lower clips for shroud and bolt onto upper bolt locations on rad .....  than one maybe two e fans on it...
Offline heep-a-lop
  • EMF WHORE
« Reply #103 on: November 05, 2012, 10:06:51 AM »
here i will go snap a picture of my rad and what i am thinkin....
Offline heep-a-lop
  • EMF WHORE
« Reply #104 on: November 05, 2012, 10:55:10 AM »
the first two pictures show yourmounting locations for said shroud and the last on gives u a idea of what i was thinking... ddint have a big enough piece to cover the whole rad... but in theory it should all be cutable on the plasma including the holes for fan or fans.....
