Author Topic: Who machines flywheels in Calgary?  (Read 2650 times)
« on: October 17, 2011, 04:16:00 PM »
Anybody know who does this work?
Re: Who machines flywheels in Calgary?
« Reply #1 on: October 17, 2011, 04:33:45 PM »
Jim Titmus
phone 403-807-8747 (hope its current, if not let me know)
Use my name as a referral.
Very well respected guy in Calgary
« Reply #2 on: October 18, 2011, 12:50:11 AM »
Don't do it, its bad for the flywheel.   Google will bring up lots of horror stories so no need to post mine.
« Reply #3 on: October 18, 2011, 09:04:50 AM »
I was talking to Steve (Rookie) yesterday and he also said it was a bad idea to machine the TJ flywheel, apparently it's a bit concave and not flat.
I'm just gonna clean it up and install the new clutch.
Vince
« Reply #4 on: October 18, 2011, 10:34:54 AM »
Depends on the clutch you use. Some aftermarket clutchs are designed for a re-surfaced(flat) flywheel.
« Reply #5 on: October 18, 2011, 10:51:19 AM »
Most shops just use a palm sander with like 60 grit sandpiper and do not spend a lot of time maybe a minute or so get rid of the hotspots and glaze but do the whole surface.
« Reply #6 on: October 18, 2011, 11:28:40 AM »
That's pretty much what I have planned and I'll be installing an OEM Jeep clutch.
Vince
Offline Knox
« Reply #7 on: October 18, 2011, 07:51:58 PM »
hmm good to know, I was not aware of this non flat flywheel issue
2003 TJ
Offline XJHERO
  • Soberphobic
« Reply #8 on: October 19, 2011, 08:52:31 PM »
i dont think sandpaper will get rid of hot spots, you have to cut that crap off. It might look like its gone but it goes deeper than the surface.
Just saying
DD
Get at me Wolf
Offline 4PLAYZJ
« Reply #9 on: October 23, 2011, 11:42:23 AM »
To have it done properly you don't "Machine" flywheels you have to have them ground.  Call Larry's transmission in the S.E.  They are just up the hill from modern.
