Author Topic: Superwinch Giveway on Jeepforum  (Read 5380 times)
Offline FirstTimer
  • Gettin there!
Re: Superwinch Giveway on Jeepforum
« Reply #1 on: October 18, 2011, 04:09:11 PM »
just gotta find someone giving away a winch plate and you're golden............ ::)
« Reply #2 on: October 18, 2011, 04:12:36 PM »
Why you need one?
I was going to cut mine up tonight to use as scrap to practice welding...
« Reply #3 on: October 18, 2011, 04:16:05 PM »
Im still upset that i offered you money to hold that one Johnny and then you sold it to Robin....
Offline fug
  • Airdrie Pick n Pull
« Reply #4 on: October 18, 2011, 04:24:51 PM »
Sad thing is I didn't even really need it ... its under the bench somewhere.
Fug
TJ Rubicon
Offline FirstTimer
  • Gettin there!
« Reply #5 on: October 18, 2011, 04:45:38 PM »
I do need a winch yes!  However, I do realize this winch is a peice, but its worth a try, cuz I think a brand new free winch is better than no winch at all.
« Reply #6 on: October 18, 2011, 10:56:09 PM »
You "need" a winch or " want" one ?
Do you do a lot of solo wheeling?
Do you hunt or fish deep in the bush by yourself?
 It's easier to get a tug from your fellow Jeepers with a strap than it is to unspool and drag out that cable. Dunno? I've owned 4 winches over the years and I've only ever used them for long and greasy hillclimbs a dozen or so times. Yes, I know it's poor form to
 always rely on other people's winches, but ask yourself why you think it's imperative to have 100 plus pounds of weight up front. I've found that a lot of guys buy one because it oozes "true 4x4" to the Offroad layman . A winch was always near the end of my modification list when I was starting new projects. Buy one when funds permit or if you get a smokin deal on one but don't be in too much of a hurry. Lots of Jeepers on runs that are more than willing to yank out a stuck guy...after pointing and laughing that is.
« Reply #7 on: October 18, 2011, 11:02:43 PM »
The only time I've used mine is to winch myself up a telephone po..I mean pull myself  out when I got stuck in the back alle...err...  :-X
I think I have 4 or so extra winches in the garage somewhere. Maybe 5. By the time you have money I'll have a couple more I got cheap off of Justin because his woman found out how much he spent on Jeep parts again.
Offline Raspberry
« Reply #8 on: October 19, 2011, 12:00:29 AM »
Baaaaaaaaaaahahahahahaha good burn!!
« Reply #9 on: October 19, 2011, 09:32:06 AM »
Yes, I know it's poor form to always rely on other people's winches, but ask yourself why you think it's imperative to have 100 plus pounds of weight up front. I've found that a lot of guys buy one because it oozes "true 4x4" to the Offroad layman . A winch was always near the end of my modification list when I was starting new projects. Buy one when funds permit or if you get a smokin deal on one but don't be in too much of a hurry. Lots of Jeepers on runs that are more than willing to yank out a stuck guy...after pointing and laughing that is.
I agree that always relying on other people's winches to get you out is definitely bad form. It's not a big deal for stocker and near-stock runs out at McLean...but when you start getting into more challenging runs, having a winch means that you're more likely to be able to contribute to the group as a whole making it through...as opposed to relying on the group to drag you through. I'd rather see someone spend their mod budget on a good quality 8000 pound winch than on a craptacular spacer lift with cam bolts. Wheel you rig the way it is now, save your disposable income for six months, buy a good quality used winch (or a new one from Jay), and be ready to contribute the group's progress down the trail.
There are definitely runs where you'll be required to have a working winch - and some runs where a working winch is the only thing that will get a near-stock vehicle through. There are obstacles that probably shouldn't be tried if you don't have a working winch - because there is no safe way to get someone into place to pull you out.
While a winch isn't necessarily a "need to have" it's a good insurance policy to have in place - especially for newer drivers in near-stock rigs. That way when you try something and choose the wrong line, you aren't completely reliant on the rest of the group to rescue you.
Offline FirstTimer
  • Gettin there!
« Reply #10 on: October 19, 2011, 11:03:38 AM »
Good Advise guys! I didn't really consider the weight issue, is there a solution for TJ's where you can remove the winch when DD, such as carriers I have seen for trucks?
My thought process was that it would be a better investment at this point then lockers. Especially, considering I am running on stock TJ axles, and plan on upgrading down the road at which point I will want lockers anyway, so why spend the big bucks twice, when I can spend "middle of the road" money on something that I will have for a while and provide insurance.  Plus, I would like to contribute when I do go wheeling and would like to head out wheeling with buddies who have dirt bikes and quads, therefore needing a winch.
« Reply #11 on: October 19, 2011, 11:05:50 AM »
This makes a lot of sense. Unless your name is Waytec, you ain't getting pulled out by a quad.
« Reply #12 on: October 19, 2011, 12:08:39 PM »
Just pony up the dough and buy one dude. If ur gonna be wheeling a stock rig for a while (and let's be honest u will be).  People will get sick and tired pretty quickly draggin ur stock jeep out of everywhere.  You want to contribute? Get self sufficient........ Guys don't build their rigs with lockers, winches and 35s to 'help' stockers out......  Just my .02.  Just buy one off Avnine. He's got a 9k for sale.
« Reply #13 on: October 19, 2011, 01:02:59 PM »
ummm, i think that he does want a winch, it would be tubby that threw in the 'use others' card. :rollingeyes: :flipoff2:
« Reply #14 on: October 19, 2011, 01:07:07 PM »
Ummmm....ya.....you see, Johnny doesn't actually read before he posts. He skims random posts in the thread, and then uses his magic 8 ball to determine what he's going to post. Then he edits his post to make it seems more offensive.  ;)
