Author Topic: Gears, gears, gears  (Read 2216 times)
Offline BUKI
  • Project Fugly
Gears, gears, gears
« on: November 12, 2011, 10:03:47 PM »
I just bought a set of 33s quite happy with the size but will eventually go to 35s. Should I go with 4.56s or go straight to 488s??  Would 488s make my engine scream doing 110 on the highway with 33s.??  Oh yeah 4l yj
Offline WK2008
Re: Gears, gears, gears
« Reply #1 on: November 12, 2011, 10:11:02 PM »
There are a few guys running 4.88 with 35s and they are super happy with that setup. 4.56 is a bit tall and 5.13 is overkill. You can't go wrong @ 4.88 and 35s and your fuel mileage will jump up too. Bonus and bonus :)
« Reply #2 on: November 12, 2011, 10:17:32 PM »
I think that 4.88's with 33's will be a little short for highway running, but not the end of the world.
« Reply #3 on: November 12, 2011, 10:47:08 PM »
4.88 on 35 here and it's fairly close to stock, have to shift down on hills.  4.88 on 33 would be nice on the highway, rev a little more but that makes little difference in fuel economy as it's the drag of the jeep and the hardness of the tires that does the most damage.
« Reply #4 on: November 12, 2011, 11:14:40 PM »
I,m running 4.11 diffs with 33. No illusions here have polished dana 30 35 combo and have no intention of ever going to bigger tires for fear of breakage. Moter has free flow exhaust no cat and fresh air intake mods. Has long legs on the highway and gets up to 22 mpg. 456 would have killed mileage for me.  If you have a dana 44 in the back I would go 456 for sure to go with the 35s. If you go with a wide or heavy 35 then 4.88 s.
Offline Jrama
« Reply #5 on: November 13, 2011, 09:52:59 AM »
4.88 and 35's rev noticeably higher than stock on the highway but gives you about the same power as stock. I run around 3 grand at 110kph, making something like 120 kph annoying to hold but i do it anyway.... I ran 4.88's with 33's and as long as you don't have to hold 110 kph for long durations it is ok. The drive out to Mclean is a little annoying with 4.88's and 33's but it is very doable.
Basically as long as your not going to be driving out of town it is livable, but could wear on your nerves if your commute demands 110kph everyday. However around town it is a blast driving with 4.88's and undersized tires, its like a go cart.
I should also mention that while 4.88 may rev a little high even with 35's for highway use, any less power and it would be kind of crappy. So IMO if 35's are the final tire size, 4.88's are your best bet.
« Last Edit: November 13, 2011, 11:59:03 AM by Jrama »
« Reply #6 on: November 13, 2011, 12:49:00 PM »
488s and 33's is fine.
Offline BUKI
  • Project Fugly
« Reply #7 on: November 13, 2011, 03:32:22 PM »
Thanx boys I think will do 488s
Offline Knox
« Reply #8 on: November 14, 2011, 09:56:58 AM »
But if 33s are your end goal are 456 more ideal? with regular 110kph commutes
2003 TJ
Offline BUKI
  • Project Fugly
« Reply #9 on: November 14, 2011, 11:50:39 AM »
Eventually 35s. I have a ford 8.8 Dana 30. But then there's steering to address and a little more lift as 3" Won't clear 35s.
« Reply #10 on: November 14, 2011, 12:24:16 PM »
i ran 5.13's on 35's and they were a bit over kill but i was planning on going 38's at the time of install
4.88's ull love
« Reply #11 on: November 14, 2011, 01:28:47 PM »
put a 2" body lift on it, run some TJ flares and cut out the rear fenders (this will be covered by TJ flares)  more than enough room for 35s.
« Reply #12 on: November 14, 2011, 03:58:54 PM »
Oh, an 8.8
If you arent spooling it, then consider 4.56
It will require you to carve less of the teeth out in order to get the cross pin into the carrier.
Offline IgniteTJ
« Reply #13 on: November 18, 2011, 10:20:01 AM »
Hey guys question to add to this.. I know my truck isn't a jeep but you all are still a fount of information  :P I want to re-gear my truck as it only has 3:55's right now.. If I wanted to comfortably run 35's would 4:10's be alright or do I have to go right up to 4:56's? I have a 5.2L v8 in it.. Thanks! ;D
« Reply #14 on: November 18, 2011, 10:27:25 AM »
4.10's would be plenty with a v8
