Author Topic: No headlights, need to drive tonight!  (Read 1510 times)
Offline Marco
« on: November 18, 2011, 02:45:01 PM »
headlights in my sisters jeep went out (both) but high beams work, anyone got an idea? I'm not in town to look and she needs to drive after work.  2007 wrangler x unlimited
locked and loaded
Re: No headlights, need to drive tonight!
« Reply #1 on: November 18, 2011, 03:14:12 PM »
daytime running lights work?  might the that DRL module possibly.  they suck on plenty of other dodge vehicles.
Offline Marco
« Reply #2 on: November 18, 2011, 03:48:31 PM »
Hmm ok. Was hopin for quick fix but that doesn't really exist. I'll look into that module. Thanks!
locked and loaded
« Reply #3 on: November 18, 2011, 04:32:32 PM »
It is ... Just unplug the bastard
Offline Marco
« Reply #4 on: November 18, 2011, 04:48:54 PM »
Unplug that module? Where is it?
locked and loaded
« Reply #5 on: November 18, 2011, 05:07:16 PM »
I'm not too sure on a JK  but i'm sure you can find out on google...
« Last Edit: November 18, 2011, 05:30:39 PM by SwampSinger »
« Reply #6 on: November 18, 2011, 05:09:24 PM »
Quote
There is a 3 inch square black module that controls this function and when they fail, the lights fail to turn off. The module is located up on the firewall.......roughly in the center
if it's messed up; it will be real hot. I took mine out about 5 years ago.
it almost burnt my Jeep down!  >:(
« Last Edit: November 18, 2011, 05:12:11 PM by SwampSinger »
« Reply #7 on: November 18, 2011, 07:41:49 PM »
I don't think that it's a separate module on the JK. The lights and every other thing on a JK seem to be run directly off the computer. I've just flashed mine so that my fog lights are now my DRL.
Offline Asia
« Reply #8 on: November 18, 2011, 07:56:14 PM »
I have a similar problem with my '94XJ:  I have DRL, I don't have low beams, I only have high beams when I pull and hold the turn signal stalk, my high beams won't stay on.  The bulbs (both high and low beam) are good - I swapped them over to my YJ  and they worked, the headlight fuse under the hood looks good, I suspect the relay? or the dash switch?  I don't know where the relay is, and I couldn't get the switch fully out after pulling apart the knee kick panel and dash face trim, pulling the knob (via pushing the little button underneath) and unscrewing the retaining "nut".
near stock advocate
Offline Marco
« Reply #9 on: November 19, 2011, 07:15:06 AM »
Thanks fellas, ended up un
locked and loaded
Offline Marco
« Reply #10 on: November 19, 2011, 07:16:31 AM »
Oops, unplugged a bunch of stuff and re-plugged it back in and they worked. cold temps of the season always seem to trigger dumb stuff. Thanks again
locked and loaded
