Author Topic: 2004 Jeep TJ Sport - Recomended Tire Pressure 225/75/15  (Read 1248 times)
Offline crusty
« on: December 10, 2011, 05:24:05 PM »
Hi Folks.
I bought this Jeep recently...spare tire and build sheet show 225/75/15 tires but placard on the door shows 215/75/15 with recommended pressure at 32 PSI. I'm thinking that it's the same for 225 and wondering if anyone can check their placard if they have 225/75/15 and see what that says.
Thanks a bunch.
Crusty
Offline Tyn Pow
Re: 2004 Jeep TJ Sport - Recomended Tire Pressure 225/75/15
« Reply #1 on: December 10, 2011, 08:22:34 PM »
Be careful, with a 10 mm tread width increase your whole drivetain could rip apart.
Having said that, I suggest 31.783 psi for the wider tires.
« Reply #2 on: December 10, 2011, 08:35:03 PM »
also 7.5 cm taller - the atmosphere is less dense at higher altitudes so may want to lower it a bit more, maybe 31.597
« Reply #3 on: December 10, 2011, 09:41:21 PM »
Asshats... buddy has a few posts and you give him the gears...    run from 25 to 28 psi...  you will be fine...
Offline crusty
« Reply #4 on: December 11, 2011, 03:16:21 PM »
I guess being this anal about tire pressure.....I asked for replies like this....LOL
Cheers.
Crusty
« Reply #5 on: December 11, 2011, 10:47:06 PM »
if you can take some teasing you will be OK here.
