Toggle navigation
Login
Register
Welcome,Guest
1 Hour
1 Day
1 Week
1 Month
Forever
4x4 Related Groups
Tech Talk
2004 Jeep TJ Sport - Recomended Tire Pressure 225/75/15
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: 2004 Jeep TJ Sport - Recomended Tire Pressure 225/75/15 (Read 1253 times)
crusty
Winch Wench
on:
December 10, 2011, 05:24:05 PM »
Hi Folks.
I bought this Jeep recently...spare tire and build sheet show 225/75/15 tires but placard on the door shows 215/75/15 with recommended pressure at 32 PSI. I'm thinking that it's the same for 225 and wondering if anyone can check their placard if they have 225/75/15 and see what that says.
Thanks a bunch.
Crusty
Logged
Tyn Pow
Budget Lift
Re: 2004 Jeep TJ Sport - Recomended Tire Pressure 225/75/15
Reply #1 on:
December 10, 2011, 08:22:34 PM »
Be careful, with a 10 mm tread width increase your whole drivetain could rip apart.
Having said that, I suggest 31.783 psi for the wider tires.
Logged
FiEND
Talks waaay too much!
Wrecking Ball
Reply #2 on:
December 10, 2011, 08:35:03 PM »
also 7.5 cm taller - the atmosphere is less dense at higher altitudes so may want to lower it a bit more, maybe 31.597
Logged
1Wide2High
ILV2FRT
'97 TJ [sold]
'17 JK Rubicon
specialk
CJA Executive
Reply #3 on:
December 10, 2011, 09:41:21 PM »
Asshats... buddy has a few posts and you give him the gears... run from 25 to 28 psi... you will be fine...
Logged
04 TJ Rubi
crusty
Winch Wench
Reply #4 on:
December 11, 2011, 03:16:21 PM »
I guess being this anal about tire pressure.....I asked for replies like this....LOL
Cheers.
Crusty
Logged
FiEND
Wrecking Ball
Reply #5 on:
December 11, 2011, 10:47:06 PM »
if you can take some teasing you will be OK here.
Logged
1Wide2High
ILV2FRT
'97 TJ [sold]
'17 JK Rubicon
Print
Pages: [
1
Go Up
« previous
next »
4x4 Related Groups
Tech Talk
