Author Topic: re;jeeptj2003  (Read 2091 times)
Offline el duke
re;jeeptj2003
« on: December 28, 2011, 04:11:50 PM »
 Well i bench tested the starter,it works fine
AAm not getting any power from the ignition,
to the starter,relays are ok and fuses are ok
any suggestions?
Offline apeman
  • not as grumpy
Re: re;jeeptj2003
« Reply #1 on: December 28, 2011, 04:19:15 PM »
Check your grounds as a start.
Getting grumpier every day.
Re: re;jeeptj2003
« Reply #2 on: December 28, 2011, 09:27:26 PM »
neutral safety switch?
Offline el duke
Re: re;jeeptj2003
« Reply #3 on: December 29, 2011, 01:01:04 PM »
 I will check the grounds today.
This is a standar trans. so i dont think the neutral switch applies,
but thanks.
What about a clutch relay?
The last time this happened i had to replace sterring column assembly cause actuator switch was broken 1200 bucks
Offline Darkcalling
Re: re;jeeptj2003
« Reply #4 on: December 29, 2011, 01:28:19 PM »
Neutral safety switch clutch relay same beast really but check it first they go out on occasion.
1999 Grand Cherokee Leredo 31s, 2000 TJ Sahara stock with 31s, 2007 Stang GT ragtop cold air and exhaust, 2011 Ram 3500 Cold air and exhaust so far.
Offline binare
Re: re;jeeptj2003
« Reply #5 on: December 29, 2011, 04:45:42 PM »
but thanks.
or you could buy the actuator switch at napa for 40 bucks.
Re: re;jeeptj2003
« Reply #6 on: December 29, 2011, 06:36:43 PM »
come on   just install a push button start .                       ;D ;D ;D
Offline el duke
Re: re;jeeptj2003
« Reply #7 on: December 30, 2011, 01:08:06 PM »
 Ya i have not looked at the ignitionn yet.
Am just working on that push button start rt. now
Offline el duke
Re: re;jeeptj2003
« Reply #8 on: January 02, 2012, 06:09:17 PM »
 Tried the push button start,it worked once!!!!!!!!!
Thought i had her licked.Did not work a gain.
Something must be broken in the ignition,i even moved the
20amp fuse in glove box to no avail.
Anyone else have this problem?
BEATS ME?
Offline el duke
Re: re;jeeptj2003
« Reply #9 on: January 06, 2012, 06:55:47 PM »
 Finally got the jeep in the garage.
Pulled apart the ignition,and it was a broken,
ignition actuator pin.Here we go again! Part not sold seperately,
pick a part, i guess ,FRICKIN POT METAL PIECE,what challenged
idiot came up with this schematics for this
Offline binare
Re: re;jeeptj2003
« Reply #10 on: January 08, 2012, 04:43:13 PM »
Why dont you just buy a new one instead of wasting your time like this?
Offline el duke
Re: re;jeeptj2003
« Reply #11 on: January 11, 2012, 03:43:34 PM »
 Ya after all that it was the
actuator.AA piece fell off a fter disassembling
steering column,i knew that was the problem.
Thanks for all the input.
I just was not sure  ;D
