Author Topic: Durango power steering upgrade for TJ  (Read 3857 times)
« on: February 14, 2012, 07:26:15 PM »
I picked up a Durango steering set last weekend for the TJ.
Now, I went whole hog and took the box, pump, and cooler. As it's time to get moving on this, I'm having second thoughts about the pump and cooler. I know the box swaps right over - any reason the pump won't? Before I rip it off?
Offline JENSSEN
    • Racing For The Cure
Re: Durango power steering upgrade for TJ
« Reply #1 on: February 14, 2012, 07:30:05 PM »
Just so you know you may have to "massage" the tube in front of the box to fit it,.. What year did you get box wise?
www.racingforthecure.ca
« Reply #2 on: February 14, 2012, 07:31:28 PM »
From a 99 V8.
« Reply #3 on: February 14, 2012, 08:17:17 PM »
Well, certainly doesn't look like it would fit....oh well.  :(
« Reply #4 on: February 14, 2012, 08:25:29 PM »
sawzall Darcy ;)
and a hammer
« Reply #5 on: February 14, 2012, 08:34:40 PM »
sawzall Darcy ;)
and a hammer
Sorry, my mistake on semantics....it will not BOLT up correctly.
Give me a big enough hammer and I can get a 5.9L CTD in there.  :D
Offline JENSSEN
« Reply #6 on: February 14, 2012, 08:49:53 PM »
It should bolt in,.. It's just a touch longer unless they changed in 99
« Reply #7 on: February 14, 2012, 09:07:38 PM »
You talking the box, or the pump?  I know the box will fit.
« Reply #8 on: February 15, 2012, 07:19:04 AM »
I put one in my 99 XJ.... I took the Durango box out of a TJ. It's tight but it fits.
It will limit your turning radius a bit...
Offline WK2008
« Reply #9 on: February 15, 2012, 07:56:31 AM »
How about a Durango upgrade for your TJ :)
« Reply #10 on: February 15, 2012, 03:39:39 PM »
I'll pass.  You should have bought it when yjdrew posted it up for sale.  ;D
Offline WK2008
« Reply #11 on: February 15, 2012, 04:31:57 PM »
Lol just being funny.
« Reply #12 on: February 15, 2012, 04:58:17 PM »
I know, no worries.  lol
« Reply #13 on: February 15, 2012, 04:59:39 PM »
You wouldnt need the pump. The TJ pump is very torqy as is, and nothing would be gained by running a durango one.
The only way you would want a different OEM pump is if your TJ is a 4 banger, and even then, you can esily mod the 4 banger pump to match the output of the 6 cyliner. On the 6 bangers there is usually 1 x 15 thou washer on pressure releif piston, where as on the 4 banger there are two. The flow orifaces are usually the same. Pull one of the washers out of the 4 bangers pistion and you will run the same psi as a 6 banger pump.
Pull out both and you will run about 100-150psi over stock. Drill out the oriface 1/64" and you will flow more from the stock pump. That is commonly referred to as hot rodding a stock pump. Use a good cooler, and good fluid if you hot rod. They neccesarily last to long when they are hot rodded.
Definately run the cooler either way. Its just better for the system.
The stroke on a Durango box is slightly limited compared to TJ box. Three options.
1. Put it in and leave it. If you rub already, not a big deal.
2. Have a rebuilder tear it down, the travel can be extended to that of a TJ box.
3. Use a WJ stock pitman, which is about 1-1.5" longer then a stock TJ one, with pretty much the same drop, and can be had from the dealer for under 50 bucks. They usually have them in the wharehouse right in red deer.
« Reply #14 on: February 15, 2012, 07:11:46 PM »
Thanks, that's what I was looking for. If it's not an upgrade, I won't bother. The only reason I grabbed it was because the engine was out and it was easier to just grab everything instead of separating the box.
Thanks for the info on the WJ arm too.  I'll grab one of those too.
