Author Topic: A Quality High Clearance T-Case Skid TJ  (Read 4195 times)
Offline Jrama
« on: March 26, 2012, 06:07:45 PM »
I'm looking to do a Flat belly T-case skid any particular brand or preference among the masses? Something that will be relatively easy to source in Calgary that works well. Any suggestions?
Top contenders
UCF
http://www.undercoverfab.com/transfer-case-skid-plates/51-hd-transfer-case-skid-plate-for-03-06-jeep-wrangler-tj-lj-aluminum-high-clearance.html
Genright
http://northridge4x4.ca/proddetail.php?prod=GEN-SKP8403
Savvy has that REAL nice Aluminium one....but it is a full under armour piece....and I'm not looking to spend that much, when all I want is a T-case  skid.
Offline JJonesee
06' Rubicon LJ
52' M-100
82' Scrambler x 3
Re: A Quality High Clearance T-Case Skid TJ
« Reply #2 on: March 27, 2012, 07:37:27 AM »
If you do change your mind about Savvy, let me know. I can help with pricing from them.
Offline Slewfoot
« Reply #3 on: March 27, 2012, 08:17:36 AM »
Jamal, Savvy is the way to go :)
Thanks again Bill for recommending their under armor - I couldn't be happier :)  no more high-centering for me!!!  Now, I just need to learn how to drive  ::)
Offline Jrama
« Reply #4 on: March 29, 2012, 07:46:10 PM »
The more I look into the Savvy the better option it seems to be...Huge advantage comes from just how low profile the skid is, in conjunction with overall design....it is hard to beat.
Offline X-Treme
« Reply #5 on: March 29, 2012, 10:13:49 PM »
LOVE my UCF ultra high clearance.
Offline Jrama
« Reply #6 on: March 29, 2012, 11:37:53 PM »
Who did you order it from?Do you have any pics?
« Reply #7 on: March 29, 2012, 11:48:11 PM »
Just call Matt directly (334) 797-7113
Offline Jrama
« Reply #8 on: April 01, 2012, 06:33:35 PM »
I'm liking the UCF now..., they have tons of options and are a little cheaper and still get great reviews. I'll probably do the full skid system which is similar to savvy.
Only one question remains Is the aluminium worth it? It's lighter, I just can't imagine it being too big of a difference....weight saving seems like a moot point when you consider the crap that gets bolted on to the jeep on a regular basis....I got the MTR/K's over the toyos I think that saved me enough weight that I can take on the steel skid  ;D
« Last Edit: April 01, 2012, 06:37:07 PM by Jrama »
Offline Slewfoot
« Reply #9 on: April 01, 2012, 08:26:23 PM »
Well...taking entire savvy skid under armor off and putting it back on is easier (due to weight) than it was to lift the stock skid plate into place, so I think the aluminum is worth it for that reason alone...and there's a drain hole for changing the engine oil ;)
Offline Jrama
« Reply #10 on: April 02, 2012, 05:13:18 PM »
Ended up ordering UCF Ultra high clearance system, in ALUMINIUM. Turns out shipping is a little over double for steel due to the weight...so it was enough for me to switch.
Offline binare
Re: Re: A Quality High Clearance T-Case Skid TJ
« Reply #11 on: April 02, 2012, 06:26:37 PM »
Jealous! me want. Can I come dry hump it when it lands?
Offline Jrama
« Reply #12 on: April 02, 2012, 08:51:26 PM »
You cannot
I'll post photos though :o
Anyways I need to buy a pair of rear uppers...when i spot this..http://undercoverfab.com/long-arm-upgrades/114-ucf-long-arm-upgrade-kit-for-jeep-tj-wrangler.html  I can build my 3" lift into long arm setup....in the future......
I'll probably just get currie uppers..short arms are still good right?
« Last Edit: April 02, 2012, 08:55:18 PM by Jrama »
Offline binare
« Reply #13 on: April 04, 2012, 10:22:12 PM »
What did shipping set ya back?
« Reply #14 on: April 05, 2012, 11:58:23 AM »
A little more money, but hands down a FAR superior suspension. I would strongly suggest staying away from that RC suspension.
http://claytonoffroad.com/product_info.php/cPath/17_125/products_id/355
