Author Topic: JKS DISCO ISSUE  (Read 1942 times)
Offline FirstTimer
  • Gettin there!
JKS DISCO ISSUE
« on: May 03, 2012, 10:14:15 PM »
So I've had the JKS Discos on my TJ for about 6 months and now that I have my lift kit on I need to extend them so that the sway bar is at 10*.  However, when I took them off do so, they wouldn't budge...  I soaked them in liquid wrench, but still nothing.  Has anyone had this issue, or have some hints on how loosen them up?
Offline Knox
Re: JKS DISCO ISSUE
« Reply #1 on: May 03, 2012, 11:13:33 PM »
what do you mean? like the jam nut is stuck or you simply can't thread it at all to lengthen it? I've been running mine just over a year, and mine are great, can spin them by hand.
did you try this?
[spoiler][/spoiler]
2003 TJ
Offline FirstTimer
  • Gettin there!
Re: JKS DISCO ISSUE
« Reply #2 on: May 03, 2012, 11:33:46 PM »
Jam nut spun, but can't thread to lengthen...without something to clamp the little suckers to it aint easy getting a good grip...any suggestions...
Also do you park the tj inside? Mines only been in a garage when being worked on, possible that the discos are more weathered and maybe even rusted... :-\
Offline LEMON-AID JAY
  • Bad a$$ zj owner
Re: JKS DISCO ISSUE
« Reply #3 on: May 03, 2012, 11:46:43 PM »
Bring them by the shop if you have time  and I will break them lose for you.
E-mortal customs
Www.e-mortalcustoms.com
3-2808 Ogden road s.e.
E-mail. [email protected]
Phone 403-265-6669
E-mail @ [email protected]
for all your 4x4 needs
www.piratesof4x4.com
Offline FirstTimer
  • Gettin there!
Re: JKS DISCO ISSUE
« Reply #4 on: May 04, 2012, 12:05:14 AM »
Thanks Jay, what time you around till tommorrow? As I would need to come after work.
Re: JKS DISCO ISSUE
« Reply #5 on: May 05, 2012, 11:09:14 AM »
10* is only the correct angle for STOCK. The correct answer is 0* (parallel with the ground) when the suspension in the middle of it's travel. I'll text you about using my strong arm (well, maybe I'll use my left just to be different) to spin your QD.
Offline FirstTimer
  • Gettin there!
Re: JKS DISCO ISSUE
« Reply #6 on: May 05, 2012, 02:56:00 PM »
So what is the correct angle for a 3" lift?
Re: JKS DISCO ISSUE
« Reply #7 on: May 05, 2012, 04:32:52 PM »
remove it all together ..  sway brs are over rated    ;D ;D ;D ;D ;D
Re: JKS DISCO ISSUE
« Reply #8 on: May 05, 2012, 07:13:14 PM »
Measure your up and down travel, jack your jeep until you are in the middle of it's travel, set sway bar parallel to the ground.
