Author Topic: Saggy XJ Doors.  (Read 3073 times)
Offline Aspirated
Saggy XJ Doors.
« on: September 06, 2012, 07:07:30 AM »
I have a 1998 XJ 2DR. The door hinges are worn. Far as i can see its a body shop repair as far as the bond/welding go.  Is there another repair?
Any recommendations are greatly appreciated.
Mickey.
1998 XJ
2008 KK
Offline dubbleJs
Re: Saggy XJ Doors.
« Reply #1 on: September 06, 2012, 09:30:22 AM »
Usually you can fix that with new door pins... I have the same issue on my XJ but yet to tackle it.
Offline Moogs
Re: Saggy XJ Doors.
« Reply #2 on: September 06, 2012, 11:23:17 AM »
If its the actual weld to the body letting go you can weld it, or bolt it. I did the bolt through method and have had zero issues.
Bolt through thread link:
http://www.xjtalk.com/showthread.php?t=3021
Re: Saggy XJ Doors.
« Reply #3 on: September 06, 2012, 11:33:59 AM »
I fixed mine with grand cherokee hinge brass bushing. Auto Value has them... it's about $20-$30...
It i sa royal pain the arse to get the old bushings out.
option: Duke of Hazard it out.. weld your doors and jump in the window  ;)
Offline Aspirated
Re: Saggy XJ Doors.
« Reply #4 on: September 06, 2012, 11:55:41 AM »
To clarify, its the hinge pivot itself thats worn. I was hoping there would be a replcement pivot or bushing available.
1998 XJ
2008 KK
Re: Saggy XJ Doors.
« Reply #5 on: September 06, 2012, 11:58:31 AM »
If I understand well....
It is the bushing then... it doesn't look like there are any there but ...They are there
The pins slide in the "pivot hinge"  there is a bushing there.
« Last Edit: September 06, 2012, 12:00:02 PM by SwampSinger »
Offline Aspirated
Re: Saggy XJ Doors.
« Reply #6 on: September 06, 2012, 01:47:21 PM »
the bottom of the pin is worn in the hinge. allows about 1.5' of play  up and down in the door.
1998 XJ
2008 KK
Offline 89cherokee
Re: Saggy XJ Doors.
« Reply #7 on: September 06, 2012, 05:28:39 PM »
1.5 feet of play damn thats alot, gotta be something other than the bushings.
Offline dubbleJs
Re: Saggy XJ Doors.
« Reply #8 on: September 06, 2012, 06:16:10 PM »
Haha...hmmm that's one idea! Or just take the doors off like the cool kids are doing these days... :P
Good to know about the ZJ bushings, are the XJ ones not brass?
Hahaa...I thought the same thing but was gonna let it slide
Re: Saggy XJ Doors.
« Reply #9 on: September 06, 2012, 07:38:53 PM »
That's all they had at the store on Bannister at the time..... they fit on the XJ. I think it's the same application (might want to double check)
