Author Topic: Steel Brake Lines...  (Read 2074 times)
Offline Jrama
« on: May 18, 2014, 08:43:33 PM »
I cut into the steel brake line on my rear axle with a sawzall.... Just nicked the tube... What is the easiest way to fix it?
Offline apeman
  • not as grumpy
Re: Steel Brake Lines...
« Reply #1 on: May 18, 2014, 09:28:01 PM »
Buy a length of tube, bend it and replace it. Bleed the brakes and tadaaa. Fixed.
Having a flare kit and small tubing cutter will make the job a lot easier.
You can also buy pre bent replacements, but that takes the headache out of it.
Getting grumpier every day.
Offline BUKI
  • Project Fugly
Re:
« Reply #2 on: May 18, 2014, 09:47:33 PM »
Yeah. Just get a pre-flared straight piece from any parts store and bend it to match. Shouldn't be more than 10$.  Use a piece of string around all your bends to get a close measurement. You wouldnt want to get back to your place and realize its too short.
Sent from my Nexus 5 using Tapatalk
Offline apeman
  • not as grumpy
« Reply #3 on: May 18, 2014, 10:40:53 PM »
I also have flare kits and cutters if you need to borrow them
Offline Jrama
« Reply #4 on: May 19, 2014, 12:39:01 PM »
Thanks I may take you up on that offer, depending on what Auto value has on the shelf.
Cheers
Offline LLYJ
  • carport ghetto fab
« Reply #5 on: May 20, 2014, 03:38:14 PM »
If you can't find exact go a little longer and create a coil in a safe place by wrapping the line around a can of paint or what-have-you (assuming you don't have access to a proper bender)
05 Dodge 2500HD hauler
« Reply #6 on: May 20, 2014, 09:52:43 PM »
You can get hand bendable lines at Greggs Dist.... it makes life a whole lot easier.
They use it for high end cars. I think it has a bit more copper in the material. It bends without kinking.  8)
It's a bit more $$ but worth every pennies...
Offline Jrama
« Reply #7 on: June 11, 2014, 08:26:22 PM »
Ok....
As it turn out a Dana 44 on a TJ is a bitch to get brake line for. The stock rubber line is actually crimped to the hardline as one piece....There are no replacements readily available.
OEM brake line is $350+.....yes lol no typo there...
The Crown or Omix  replacement part is about $27 but it was two weeks out.
What I did was buy a front hose for a TJ, bought some hand bendable hard line from Bowness Auto and made it work. All in $24 and an instant fix.
