Toggle navigation
Login
Register
Welcome,Guest
1 Hour
1 Day
1 Week
1 Month
Forever
4x4 Related Groups
Tech Talk
Steel Brake Lines...
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Steel Brake Lines... (Read 2011 times)
Jrama
That CB Yapper
on:
May 18, 2014, 08:43:33 PM »
I cut into the steel brake line on my rear axle with a sawzall.... Just nicked the tube... What is the easiest way to fix it?
Logged
apeman
Talks waaay too much!
not as grumpy
Re: Steel Brake Lines...
Reply #1 on:
May 18, 2014, 09:28:01 PM »
Buy a length of tube, bend it and replace it. Bleed the brakes and tadaaa. Fixed.
Having a flare kit and small tubing cutter will make the job a lot easier.
You can also buy pre bent replacements, but that takes the headache out of it.
Logged
Getting grumpier every day.
99 XJ - It's got sum stuff ,Noel free stuff..
98 ZJ - It's just ugly, but bigger than your Rubi
BUKI
Project Fugly
Re:
Reply #2 on:
May 18, 2014, 09:47:33 PM »
Yeah. Just get a pre-flared straight piece from any parts store and bend it to match. Shouldn't be more than 10$. Use a piece of string around all your bends to get a close measurement. You wouldnt want to get back to your place and realize its too short.
Sent from my Nexus 5 using Tapatalk
Logged
apeman
not as grumpy
Reply #3 on:
May 18, 2014, 10:40:53 PM »
I also have flare kits and cutters if you need to borrow them
Logged
Jrama
That CB Yapper
Reply #4 on:
May 19, 2014, 12:39:01 PM »
Thanks I may take you up on that offer, depending on what Auto value has on the shelf.
Cheers
Logged
LLYJ
UberWheeler
carport ghetto fab
Reply #5 on:
May 20, 2014, 03:38:14 PM »
If you can't find exact go a little longer and create a coil in a safe place by wrapping the line around a can of paint or what-have-you (assuming you don't have access to a proper bender)
Logged
51 Willys CJ3A - V6, SM420, T18, D44/27 lockers
93 YJ, starting to see light at the end of the carport
98 ZJ, 5.2l - DD with too many go go gadgets
05 Dodge 2500HD hauler
SwampSinger
CJA Members
Baconator
Reply #6 on:
May 20, 2014, 09:52:43 PM »
You can get hand bendable lines at Greggs Dist.... it makes life a whole lot easier.
They use it for high end cars. I think it has a bit more copper in the material. It bends without kinking.
It's a bit more $$ but worth every pennies...
Logged
Jrama
That CB Yapper
Reply #7 on:
June 11, 2014, 08:26:22 PM »
Ok....
As it turn out a Dana 44 on a TJ is a bitch to get brake line for. The stock rubber line is actually crimped to the hardline as one piece....There are no replacements readily available.
OEM brake line is $350+.....yes lol no typo there...
The Crown or Omix replacement part is about $27 but it was two weeks out.
What I did was buy a front hose for a TJ, bought some hand bendable hard line from Bowness Auto and made it work. All in $24 and an instant fix.
Logged
Print
Pages: [
1
Go Up
« previous
next »
4x4 Related Groups
Tech Talk
