Author Topic: Rear ZJ vibes after lift  (Read 3268 times)
Offline Reznor
« on: May 22, 2014, 08:37:42 PM »
98 5.9 was fine before the lift.
Lowdown: f>r swap lift.   Rough Country 3.5" with fixed lower control arms.
Lots of rear vibration on accell especially between 30k and 80k.  Smooths out at 100k.
Rear pinion angle and tc output roughly identical; no more than 2 degree difference.
Adjustable control arms wouldn't help with it being damn near dead on right?
Tried a 1" tc drop and it might actually have made it worse.
Ujoints appear to have little play - though I haven't taken the rear DS off so it's hard to tell.
Front driveshaft removed to replace cv with ujoint slip ds.  So far still removed to isolate rear issues first.
Any help would be appreciated.
Offline cjust
Re: Rear ZJ vibes after lift
« Reply #1 on: May 22, 2014, 08:56:57 PM »
Sorry to go off topic i got some rear lift coils if you want.... Cheap
J ust
E mpty
E very
P ocket
Offline cjust
« Reply #2 on: May 22, 2014, 09:02:50 PM »
My zj just had my 5.5" lift installed with fixed rears and it has  0 vibes. So your pinion angle must be off
J ust
E mpty
E very
P ocket
Offline Reznor
« Reply #3 on: May 22, 2014, 09:10:00 PM »
I know zj's are supposed to lift wonderfully without the sye and all that jazz.  But I swear, the pinion angles are 2 degrees off at most - and I thought that was an acceptable difference?  If I need adjustable uppers I'll buy them - but I don't want to burn cash.
cjust - I think I saw you selling coils.  Thought about it, then realize my fronts actually work just fine for me.  Thx.
« Last Edit: May 22, 2014, 09:11:51 PM by Reznor »
Offline cjust
« Reply #4 on: May 22, 2014, 09:21:01 PM »
Are your uppers fixed now?
J ust
E mpty
E very
P ocket
Offline apeman
  • not as grumpy
« Reply #5 on: May 22, 2014, 10:05:23 PM »
Have you taken a look at your trans mount and engine mounts ?
Getting grumpier every day.
Offline Reznor
« Reply #6 on: May 22, 2014, 10:23:55 PM »
Uppers are currently stock.
No, have not looked at mounts - but why would they fail the very moment I put the lift in?  It was fine.
Offline apeman
  • not as grumpy
« Reply #7 on: May 23, 2014, 12:35:35 AM »
I had a wierd vibe after doing my lift. Turned out my trans mount was shot. Cleared itself up after changing it out
Offline Reznor
« Reply #8 on: May 23, 2014, 08:43:16 AM »
ok thanks - I'll check it out.
« Reply #9 on: May 23, 2014, 08:47:35 AM »
thats your problem right there. rear arms are to long with this kit.  common problem with the RC F/R (according to the interwebs) adjustable uppers should fix it or swap the stock ones back on
Offline Reznor
« Reply #10 on: May 23, 2014, 12:15:11 PM »
Yeah, that's what I'm thinking.  Even though the angles don't look too out of line, if it's primarily happening on acceleration then it's probably pushing the pinion down a couple of degrees more than it likes.
Looks like it's new uppers.
I have to install the front driveshaft to see if that requires new uppers as well.  However, if I'm right, acceleration (with front wheels engaged) would have the opposite effect and bring the pinion up - so I might be ok as long as the fixed control arms don't push the pinion too low under non-acceleration situations.
I WAS getting horrible vibes from the front as well, but I know that very likely would have been caused by the axle-side CV that used to be there.  It was on quite an angle after the lift.
Fingers crossed.
Offline cjust
« Reply #11 on: May 23, 2014, 02:05:35 PM »
Listen to johnny. Hes a zj guru.
J ust
E mpty
E very
P ocket
« Reply #12 on: May 23, 2014, 02:58:59 PM »
Offline apeman
  • not as grumpy
« Reply #13 on: May 23, 2014, 06:17:11 PM »
Seriously??? Johnny is a burger joint guru. He's never had a zj that didn't either get parted out or backyard butchered.
Offline cjust
« Reply #14 on: May 23, 2014, 07:21:51 PM »
[hquote author=apeman link=topic=29033.msg181572#msg181572 date=1400890631]
[/quote]aw man thats just cruel
J ust
E mpty
E very
P ocket
