Author Topic: May need a really heavy bumper after this..  (Read 2757 times)
Offline KorzaXJ
    • Korza Design
« on: May 27, 2014, 01:11:42 PM »
I have pretty much ZERO articulation. I could remove the front sway bar, that should help a bit, but I flex like a neon haha
https://www.youtube.com/watch?v=aqVdBnC3WOA&feature=youtu.be
Re: May need a really heavy bumper after this..
« Reply #1 on: May 27, 2014, 03:27:33 PM »
Ouch, that is stiff.  What springs do you have?
Offline Dingleberry
« Reply #2 on: May 27, 2014, 03:31:57 PM »
Definitely disconnecting the front sway bar would help!
Also, if you have a rear sway bar, remove it completely.
And whatever you do, don't do this:
 http://www.youtube.com/watch?v=lDlQPnyJ42s
Offline XJHERO
  • Soberphobic
« Reply #3 on: May 27, 2014, 04:20:43 PM »
And don't forget to put it in park!
DD
Get at me Wolf
Offline BUKI
  • Project Fugly
Re:
« Reply #4 on: May 27, 2014, 04:36:55 PM »
That's most certainly a sway bar  in the front. Pop that sucker and waaay different. The rear?? Do xjs have a swaybar in the rear??
Sent from my Nexus 5 using Tapatalk
« Reply #5 on: May 27, 2014, 07:09:05 PM »
Yes there is a rear swar bar on an xj. Known issue with a lift and rear sway at flex is end of sway bar pokes out the sidewall of your tire.
Offline dubbleJs
« Reply #6 on: May 27, 2014, 07:33:05 PM »
Dang! That is mighty tippy... better get yourself some disconnects  ;)
Offline KorzaXJ
    • Korza Design
« Reply #7 on: May 27, 2014, 08:11:02 PM »
That happened to me after hours of working on it. I just gave up threw the spare on and got new tires the next thursday. I need swaybar disconnects pretty badly
Offline whitefang
« Reply #8 on: May 27, 2014, 08:58:07 PM »
x2
remove rear sway bar completely, 31 inch tires stuff well in the rear fenders
1995 xj Richmond Lock-Right front and back 2" lift 31x10.5 BFG KM 8500 superwinch
Offline KorzaXJ
    • Korza Design
« Reply #9 on: May 28, 2014, 08:09:00 AM »
there is no rear sway bar, I (at first) disconnected it, then something happened and it ended up exploding my rear tire, and snapping in two
also when i say something happened i meant, "something happened" haha. typical little whoops moment
