Author Topic: 01 XJ idling rough, dying  (Read 3115 times)
Offline EEP
« on: May 05, 2015, 07:44:42 PM »
The eep (4.0 l) is idling rough, even dying at idle. Smooths out with a little throttle. No vacuum leaks. Could it be a bad coil, bad injector?
Thanks in advance.
« Last Edit: May 05, 2015, 07:50:39 PM by EEP »
14 JKU, wife's urban 4X4.
Offline Dingleberry
Re: 01 XJ idling rough, dying
« Reply #1 on: May 06, 2015, 09:20:50 AM »
I wouldn't test those until you've first verified its not the CPS.
Offline EEP
« Reply #2 on: May 06, 2015, 10:07:04 AM »
Thanks, I ordered a new cps, will put it in this afternoon.
« Reply #3 on: May 06, 2015, 11:57:54 AM »
My 01 had this issue as well. Turned out my idle air control motor had to be replaced. You can easily take that out and clean it, and also wouldnt hurt to check the other sensors in the intake to ensure they are clean and working properly.
Offline EEP
« Reply #4 on: May 07, 2015, 03:21:12 PM »
Pulled IAC and cleaned it. Ran little better. Replaced it, what a difference. Think it had been faulty for a while.
Thanks TL.
Offline Duncan71
« Reply #5 on: May 10, 2015, 05:21:12 PM »
Think you might still have a problem.... sounded too lopy when you drove away.
Offline EEP
« Reply #6 on: May 10, 2015, 05:29:26 PM »
Ran good out wheeling yesterday.
Offline Duncan71
« Reply #7 on: May 12, 2015, 10:25:02 AM »
Probably will.   But your missing on a cylinder every once and a while.  Feel the exhaust.  Dunno, maybe its better now, but noticed it first thing when you started er up driving away.
Offline EEP
« Reply #8 on: May 12, 2015, 11:49:14 AM »
I will check it out, thanks
