Author Topic: Alternator Bearings...  (Read 740 times)
Offline Nufy
« on: November 23, 2020, 05:39:54 PM »
Not  Jeep but my 2011 Ram 1500 5.7 L Hemi.
Water pump bearing went spraying coolant all over the alternator.
I had the water pump replaced but not the alterator bearing is screaming...probably front bearing is now contaminated by the coolant.
Where can I get the bearing(s) done ?
I can remove /. re-install the alternator myself.
Thanks.
Offline Sixty4X4
Re: Alternator Bearings...
« Reply #1 on: December 08, 2020, 09:04:44 AM »
I am sure you would simply want to do a rebuilt alternator with your core as exchange. The days of what you suggest are nearing the end as it is hard to locate part numbers for seals/bearings etc. What about diodes, internal regulator etc if the alternator was apart? One used to be able to walk in to dealers and say "I would like a diode kit and front bearing for an alternator ............." Not anymore.
2008 JKU Ruby, Jeep steel bumper, 9500 winch, 2016 5.3 Chev LT & 8L90 8 spd auto, 285 Maxxis Bighorns, MC 2.5" and LC Arms.
