Author Topic: Blinker Mod  (Read 5793 times)
Offline Rookie
Blinker Mod
« Reply #15 on: August 30, 2006, 09:05:40 PM »
Quote from: "calltrex"
I should have kept the box. Cost like $15 bucks
Its a blue module that plugs into the flasher socket.
Dava
Is this flasher a 5 pin????
I've had a partsman looking for a frequency doubling disabled flasher for 3 months and according to the aftermarket manufacturers they don't make one nor are they planning to make one
Steve
TJ with some stuff
Offline calltrex
Blinker Mod
« Reply #16 on: August 30, 2006, 09:17:23 PM »
If i remember tommorow i ll look at work.
........___________
....=//___________\\=
.....(@)___JEEP_(__@)
......\____I===I____/
.../""""/........J
../""""/=(=)___....../""""/
./___/............==/""""/
....................../___
Offline Rookie
Blinker Mod
« Reply #17 on: August 30, 2006, 09:54:04 PM »
Chris
this is the wiring for ur relay based on the data sheet u posted
HTH
Steve
If u want to pick up a  flasher and give it to me along with the relay i'll do it for u
TJ with some stuff
Offline redbull
Blinker Mod
« Reply #18 on: September 01, 2006, 12:52:58 AM »
Quote from: "Rookie"
Don't put in the resistors they add heat and currunt draw to the system
Yes, but no more than a bulb does.
Offline Elsifer
Blinker Mod
« Reply #19 on: September 01, 2006, 09:18:49 AM »
Chris
HTH
Steve
I had that exact wireup, and the signals would flash at a normal rate but the on dash indicator would be lit when the lights were on.
Perhaps my blinker was farked before, I had the simple "jumper" mod done, till I read that it could start a fire, so I pulled it out. And started looking for a micro-relay.
I'm at a loss now. I'll try to re-solder and see if my blinker truly is hooped.
Otherwise, I'm off for the weeekend.
Thanks for your help Steve!
VA6CPL
Jeepless....
Blinker Mod
« Reply #20 on: September 01, 2006, 09:25:34 AM »
Chris
HTH
Steve
Steve, that is some awesome art skillz
Offline Rookie
Blinker Mod
« Reply #21 on: September 01, 2006, 06:43:49 PM »
Quote from: "BlackYJ"
Chris
HTH
Steve
No one told me I had to be able to draw to be an contruction worker
Quote
Chris
Gimmie a call when u get back and we'll hook up and u can try my
modded flasher and see if thats works before u buy a new one I'll pm u my #
Quote from: "Vinman"
Where did you get the relay Steve? I have tried to find it at RS but they told me they didn't carry it anymore.
Vince
Vince I got one at Active on 32nd I can't remember the part # but I can stop in on thurs and get it
the specs on it are
coil 12v
contacts 1A @24V
DPDT
aprox sixe L3/4" * H1/2" * D3/8"
HTH
Steve
Vince the part # at Active is
63045  DS2E-M-DC12
12vdc, 2a, DPDT relay
$5.46 + gst
Quote from: "redbull"
But why add the heat and load if you don't have to :D
Plus if Chris did that I wouldn't get to make really long posts and get my post count up :lol:  :wink:
Steve
TJ with some stuff
Offline Elsifer
Blinker Mod
« Reply #22 on: September 10, 2006, 05:44:22 PM »
So, Rookie's wiring works. In fact it works just like I had it.
The dash arrows still stay lit, except when flashing normally during blinker duty.
The culprit, two-wire led's on the front. Thats why, stock harness is three-wire. So there is more "voltage sense" stuff going on than what the relay bypasses. Anytime you see me and want to know wtf I am talking about, just ask, me show.
Cheers
Chris
PS Thanks to Rookie for stopping by and talking about an hour or so to figure this all out.
VA6CPL
Jeepless....
Blinker Mod
« Reply #23 on: September 10, 2006, 07:10:33 PM »
Quote from: "Elsifer"
Cheers
Chris
Try wiring your front LED's into the stock side marker harness, it should be a two wire harness instead of three wire.
Offline Elsifer
Blinker Mod
« Reply #24 on: September 10, 2006, 08:22:04 PM »
This is true, the side marker is a two wire harness. Though, I'm saving the side marker for something special!
I could "make" my own three wire front led, and that would entail buying a bunch of yellow led's and making my own circuit board, thus fooling the wiring gods into thinking there is a two filament bulb attached. But that would entail quite a bit of work+time+money. Of which, I'm short on all three.
VA6CPL
Jeepless....
Blinker Mod
« Reply #25 on: September 10, 2006, 09:20:52 PM »
Wire your front turn signals and your "special" side markers to the same existing side marker harness. The only downside I see is the front a side signals will flash together instead of alternating.
Vince
Offline Elsifer
Blinker Mod
« Reply #26 on: October 04, 2006, 02:47:29 PM »
Seen the new "Jeep Style" surface mount rear leds?
http://led-r-us.com/sttlights.shtml
Purty, pricey, stock looking goodness. Now with the ability to not melt kicked up snow in the winter!
VA6CPL
Jeepless....
