Author Topic: seals  (Read 1161 times)
joe
seals
« on: September 27, 2006, 09:13:08 PM »
wondering what the procedure for changing the axle seal on the front passenger side of 90 yj ,does it pull out or do you have to remove the 4 wheel vacuum arse. and put it in from that side ,thanks for any info(have the axle out)
Offline Gearhead
Re: seals
« Reply #1 on: September 27, 2006, 11:18:07 PM »
Quote from: "joe"
Remove wheel , caliper , rotor , hub/ unit bearing , axle shaft , vacuum motor . The seal is inside the disconnect housing , not easy to get it in straight without having to "create" some sort of   tool / device to draw the seal into it's bore.
seals
« Reply #2 on: September 28, 2006, 09:18:24 AM »
Yeah it pushes into the vacum setup. Pop it out with a pry bar.
To re install
Take your 36mm socket
Place seal on the socket and slide them into the vacum housing
Take a pry bar and pry on the center of the 36mm socket, slowly pressing the seal into the axle tube.
hth
joe
seals
« Reply #3 on: September 28, 2006, 03:25:59 PM »
thankyou
