Author Topic: Remembrance day  (Read 25766 times)
Remembrance day
« Reply #30 on: October 23, 2006, 10:28:13 AM »
Quote from: "fony3"
You can count me in...I like the idea of teaching us "fresh tug meat" some off roading techniques at the gravel pit before hitting the trail.
Yeah Ian is not just another pretty face  :D
Offline Matt4x4
Remembrance day
« Reply #31 on: October 24, 2006, 02:43:36 AM »
OK I am definately in. The only thing is, I dont have a CB. So can I borrow one of yours TJ54?
As for tow points, where can I pick up some for my '94 ZJ? Where should I put them? For the rear, I have a hitch.
Offline kevman
    • http://members.shaw.ca/thekevman
Remembrance day
« Reply #32 on: October 24, 2006, 08:38:41 AM »
I believe http://jeepstuff.8m.com/ is still open for appointment purchases???
If so, that's where I would go looking for tow hooks/brackets.
uh...
My shovels nicer!
unionjack
rememberence day
« Reply #33 on: October 24, 2006, 09:03:46 AM »
i think im out of this one!!!!!!!!!!!!!! the jeep needs some minor things done before they turn into major things!!!!! its almost off the road for some r&r for the jeep, have fun guys
Offline TaTtOo
    • http://www.lawrencemuller.com
Remembrance day
« Reply #34 on: October 24, 2006, 05:24:54 PM »
Hey Ian... Count me in for this one... Let me know if you need anything.  Are we meeting at the store?  What time?
Cheers
Jeepless (for now)
Offline TJ54
Remembrance day
« Reply #35 on: October 24, 2006, 06:48:24 PM »
Quote from: "Matt4x4"
Yes, you can borrow a FRS radio
No, I don't have extra CB's
I am assuming when you say when you have a hitch, you are not thinking of using a trailer ball
Offline Rookie
Remembrance day
« Reply #36 on: October 24, 2006, 08:38:16 PM »
I'm gonna try to make this one
TJ with some stuff
Remembrance day
« Reply #37 on: October 24, 2006, 09:58:15 PM »
I will be there and I have 2 extra CBs, but I believe one is already spoken for.
Offline Mudhawg
  • Rig Life
Remembrance day
« Reply #38 on: October 24, 2006, 10:09:28 PM »
if i find someone who needs a winch wench ill come
Remembrance day
« Reply #39 on: October 24, 2006, 10:12:10 PM »
I will hopefully be there, if I can get the leaky transfer case fixed.  Getting tow points was my major job needing to be done, but now that I have fluid leaking out, tow points or not there's no way she can go on the trail like that.
If I am there, I will probably be able to spot someone a CB for the day, as I managed to get a base station CB up and running on the August 19th run. Hopefully someone needing it would be all ready to have the wires run to a hot fuse or similar set up, so we're not sitting trying to fish things through the firewall (Buki can wrench my tow hooks on in the parking lot while we're doing that - he has experience already :lol:).
If I do come down from Sylvan, I'd like to get a membership if possible.  If there is anything ahead of time with that needing attention, let me know and I will make sure all the ducks are in a row. :)
Offline Matt4x4
Remembrance day
« Reply #40 on: October 24, 2006, 10:56:00 PM »
Quote from: "TJ54"
Well I found some tow points at Princess Auto, they are shackles and hooks for $13. I was going to try and hook them up to the hitch somehow. I also found some Nylon Recovery Straps 2"x30' (18k lbs) for $50.
Remembrance day
« Reply #41 on: October 24, 2006, 11:07:40 PM »
I would hazard a guess to say that every single time a "run" thread comes up, that tow points and CB's and all their quirks arise in the thread from the newbie side.
Can I make a suggestion?  Could we have an article written by someone knowledgeable (without pics is fine in the beginning) on the finer points of installing CB's and tow points made into a sticky at the top of the page?
That way, at least all you are doing is copying a link, stating for them (i.e. ME) to read it, and then come back with questions.
Thoughts?
Offline Asia
Remembrance day
« Reply #42 on: October 24, 2006, 11:47:46 PM »
If your hitch has a ball/mount that is removable and held in place with a pin and safety clip, you already have a great tow point.  Remove the ball/mount, slip the loop of your tow strap into the receiver, slide the pin through the loop and add the safety clip.  This works great, I used this method for a year before I bought the Warn shackle attachment that fits into the receiver.
near stock advocate
Remembrance day
« Reply #43 on: October 25, 2006, 09:06:05 AM »
Quote from: "Asia"
Under the right conditions, wouldn't this produce a projectile?
Remembrance day
« Reply #44 on: October 25, 2006, 09:08:06 AM »
Quote from: "dunl"
Quote from: "Asia"
Under the right conditions, anything could be a projectile.  I have seen it done, and you need to make sure you have a GOOD pin.  However, for the price you can pick up a receiver with a shackle or hook for a decent price.
