Author Topic: Remembrance day  (Read 25768 times)
Offline Matt4x4
Remembrance day
« Reply #45 on: October 25, 2006, 09:19:30 AM »
OK well I think I will go with this type of product for my rear.
http://www.tellico4x4.com/product_info.php/cPath/51_1996/products_id/18680?osCsid=d60784ca463b5402491abf91d0b9df11
its only $25. Im sure Modern Motors would have something like this. Or National. Im not sure what I am going to do for my front tow point.[/img]
Remembrance day
« Reply #46 on: October 25, 2006, 09:56:42 AM »
Quote from: "Matt4x4"
Please if you got a technical question, post it in the Technical Forum, it is more likely to be answered
Offline Asia
Remembrance day
« Reply #47 on: October 25, 2006, 08:31:05 PM »
Quote from: "dunl"
Under the right conditions, wouldn't this produce a projectile?
Describe those conditions, I'm curious.  My method is as strong as the parts: pin, hitch and how its attached to the frame.  The strap loop strength is part of the strap strength.  Obviously your "shackle/mount" is still held to the hitch by that same pin.  My method may cause abrasion of the strap against the square receiver hole if pulled from an angle, I always tried to have the pull in a straight line and never had any issues with abrasion over the year+ that I used this method for tugging and being tugged.  Granted you can not hook a winch hook to the hitch using my method.
near stock advocate
Offline aa856
Remembrance day
« Reply #48 on: October 27, 2006, 10:04:07 AM »
is it possible, i could come for this run
i have a 5.5inch lift comanche 32 inch tires tow hooks front and rear,
and i dont get out to much.
is their anything else i would need?
thanks kyle
Remembrance day
« Reply #49 on: October 27, 2006, 10:13:04 AM »
Quote from: "aa856"
thanks kyle
It is an open run so we will see you there.  As long as you have a CB are you good
Offline aa856
Remembrance day
« Reply #50 on: October 27, 2006, 12:29:45 PM »
ill buy one this week im in
Offline Lugnut
  • At least its still a Jeep...
Remembrance day
« Reply #51 on: October 28, 2006, 08:38:43 AM »
I hope to be in for this one....been way to long since the last one.
Looking foward to it.   :)
03 Black Rubi, 4"lift, 33s, Warn 9.5ti - SOLD
07 Jeep Grand Cherokee SRT8 .. 13.8 secs @100.4 mph
Remembrance day
« Reply #52 on: November 01, 2006, 11:32:24 AM »
i bought a 10,000 pound all in one at princess auto for $20.  similar to that but instead of having to put a clamp in it, the end has a large O that I loop the strap into.   looks like this  =O
red-xj-666
rememberance day run
« Reply #53 on: November 01, 2006, 06:08:38 PM »
I'd like to tag along, but I don't know where the store is. I've only been going to waiporous.
'97 xj 3"lift, 31" trxus, arb front bumper, rear tow pts, CB.
Re: rememberance day run
« Reply #54 on: November 01, 2006, 06:20:51 PM »
Quote from: "red-xj-666"
Check out this link, http://www.aurs.org/Images/map-toMcLean.jpg.  The store is about 0.5-1 km from the highway
red-xj-666
Remembrance day
« Reply #55 on: November 01, 2006, 06:22:40 PM »
thanks, I'll be there
Remembrance day
« Reply #56 on: November 01, 2006, 06:44:14 PM »
I think I'm in the right area....if some kind soul could pop this into Paint and drom some directions on it, it would certainly help our visual learners as opposed to spatial learners.  :)
m0th
Remembrance day
« Reply #57 on: November 01, 2006, 07:51:24 PM »
Here's a Google Earth placemark to where you turn off Highway 66. You can't miss the store from here.
Clicky
TOYZ
Remembrance day
« Reply #58 on: November 02, 2006, 12:10:22 AM »
Sorry Guys, My Shifts have been changed, I can't make it after all. Maybe next time.
Remembrance day
« Reply #59 on: November 03, 2006, 08:36:16 PM »
i'll be there.  should be bringing a friend with a taco that was just painted and needs some trophies.
