Author Topic: YJ problems  (Read 1128 times)
Offline 4Banger_madness
YJ problems
« on: November 06, 2006, 09:20:27 AM »
HI im new to this web site and i have a problem with my yj
It seams to run fine until i stop at a light and try to take off it studders alot and if you dont flutter the gas it will stall my dad and i hooked it up to our scanner and when it does this the injecter pulse width increases and the battery temp is not acurate also
has anyone had this problem before any suggestions would be greatly helpfull,
Nich
YJ problems
« Reply #1 on: November 06, 2006, 09:35:55 AM »
Have you checked the simple thigns like spark plugs, cap, rotor, wires, etc.?
Offline stroker sahara
YJ problems
« Reply #2 on: November 06, 2006, 05:44:48 PM »
Did you get any codes? I had problems with mine. ended up being TPS AND coil. Hard to diagnos when two problems arise at the same time and one won't trip a code :?
YJ problems
« Reply #3 on: November 06, 2006, 05:46:16 PM »
yes i have checked that and they look good. we also cleaned up the grounds and the battery teminals. it was still the same
Offline Rookie
YJ problems
« Reply #4 on: November 06, 2006, 07:05:04 PM »
Check ur fuel pressure I had a simalar prob in a gm and it was the fuel pump
TJ with some stuff
