Toggle navigation
Login
Register
Welcome,Guest
1 Hour
1 Day
1 Week
1 Month
Forever
4x4 Related Groups
Tech Talk
YJ problems
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: YJ problems (Read 1083 times)
4Banger_madness
UberWheeler
YJ problems
on:
November 06, 2006, 09:20:27 AM »
HI im new to this web site and i have a problem with my yj
It seams to run fine until i stop at a light and try to take off it studders alot and if you dont flutter the gas it will stall my dad and i hooked it up to our scanner and when it does this the injecter pulse width increases and the battery temp is not acurate also
has anyone had this problem before any suggestions would be greatly helpfull,
Nich
Logged
BlackYJ
Talks waaay too much!
YJ problems
Reply #1 on:
November 06, 2006, 09:35:55 AM »
Have you checked the simple thigns like spark plugs, cap, rotor, wires, etc.?
Logged
stroker sahara
UberWheeler
YJ problems
Reply #2 on:
November 06, 2006, 05:44:48 PM »
Did you get any codes? I had problems with mine. ended up being TPS AND coil. Hard to diagnos when two problems arise at the same time and one won't trip a code :?
Logged
If you want to run with the big dogs you have to be able to pee in the tall grass.
1989 YJ SOA, 36" SX, 4.6 Stroker...
4Banger_madness
UberWheeler
YJ problems
Reply #3 on:
November 06, 2006, 05:46:16 PM »
yes i have checked that and they look good. we also cleaned up the grounds and the battery teminals. it was still the same
Logged
Rookie
CJA Members
That CB Yapper
build it, break it, rebuild it better
YJ problems
Reply #4 on:
November 06, 2006, 07:05:04 PM »
Check ur fuel pressure I had a simalar prob in a gm and it was the fuel pump
Logged
TJ with some stuff
Print
Pages: [
1
Go Up
« previous
next »
4x4 Related Groups
Tech Talk
YJ problems
