Author Topic: XJ rear end  (Read 3360 times)
4Play
XJ rear end
« on: January 03, 2007, 03:31:01 PM »
Just looking into for a friend.  He was told by a mechanic that his rear pinion gears were gone and needed to be rebuilt for about 7 bills.  I was thiking he could just find a rear end on here and swap the rear end out in a garage.  Any ideas if that is the way to go and if anyone has one for sale.  91 XJ.  How much it would cost if someone here would be willing to do the work????
Offline SPOT
XJ rear end
« Reply #1 on: January 03, 2007, 04:46:05 PM »
450 installed have two rear diffs sitting here.need to know if its a dana diff or a 8-1/4 chrysler diff
4Play
XJ rear end
« Reply #2 on: January 03, 2007, 08:13:26 PM »
Whats the easiest way to find out???  Serial number and call dodge?
Offline SPOT
XJ rear end
« Reply #3 on: January 03, 2007, 09:09:31 PM »
look at the rear diff and mounted to the bolts that hold the diff cover on will be a tag.I need the numbers off it.Shoud be able to find one of these numbers on it 3.08,3.54,3.73,4.10.If the rear tag is missing check the front diff cover for a tag.then look at the rear diff cover does it look more round or more like a stop sign with sharper corners need to know which it looks like.If thats your jeep in the pic look at your rear diff you will have the dana diff(round looking)
Offline dubbleJs
XJ rear end
« Reply #4 on: January 03, 2007, 10:21:41 PM »
Quote from: "4Play"
This should help.
http://www.californiajeeper.com/axle.htm
Also, here's a DANA 35, has a rubber fill plug. Look like yours?
XJ rear end
« Reply #5 on: January 04, 2007, 07:17:40 AM »
The 8.25 axle is flatter on the bottom
XJ rear end
« Reply #6 on: January 04, 2007, 08:07:18 AM »
Quote from: "BlackYJ"
Did you call me Fat?
XJ rear end
« Reply #7 on: January 04, 2007, 08:10:48 AM »
I don't know what you are talking about Dom, it says flatter, so nobody was calling you fatter,  8)  8)
Got to love administrator priviledges
XJ rear end
« Reply #8 on: January 04, 2007, 08:18:36 AM »
Dom, he's not calling you fat. He's saying your bottom is flat.
How he even notices this stuff is a mystery.
4Play
XJ rear end
« Reply #9 on: January 04, 2007, 08:22:11 AM »
Holy thread hijack....!   :lol:    This is the way he is gonna go.  Does it matter if I screwed up and its a '90.
XJ rear end
« Reply #10 on: January 04, 2007, 08:24:27 AM »
Prolly not, so long as you get the ratio right.
XJ rear end
« Reply #11 on: January 04, 2007, 08:24:44 AM »
Quote from: "4Play"
If it is a 90, than it is most likely a Dana 35 axle
Offline SPOT
XJ rear end
« Reply #12 on: January 06, 2007, 10:17:22 AM »
yup in a 90 it should be the dana 35
XJ rear end
« Reply #13 on: January 07, 2007, 01:32:58 PM »
Actaully what it SHOULD have been was a D44 but Chrysler cheaped out and put in a D35 instead.  :D
