Toggle navigation
Login
Register
Welcome,Guest
1 Hour
1 Day
1 Week
1 Month
Forever
4x4 Related Groups
Tech Talk
Tire problem
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Tire problem (Read 983 times)
Mudhawg
Talks waaay too much!
Rig Life
Tire problem
on:
January 04, 2007, 12:30:57 PM »
Ok one of my 35" baja claws has a maybe 1" cut on the back side of it... were would i take this to have it fixed? (would need to be pulled off the rim im guessing
Logged
GiS
That CB Yapper
Tire problem
Reply #1 on:
January 04, 2007, 12:36:20 PM »
On a sidewall or tread block?
If on the sidewall, pull the tire off rim and use a nice big patch,
Take it to Jamie and OK Tire in Shawney (sp?) station off MacLeod, fellow wheeler and a great guy.
Logged
stuckagain
Guest
Tire problem
Reply #2 on:
January 04, 2007, 12:38:10 PM »
which direction is the cut in relation to the bead of the tire?if it is vertical from the bead (points at the bead) I can repair it. If it runs the same direction as the bead it may not be repairable.
Logged
Mudhawg
Rig Life
Tire problem
Reply #3 on:
January 04, 2007, 12:45:33 PM »
its side above were the tread and sidewall connect between 2 tread blocks... i was thinkin just patch the hell out of it and maybe put in a tube... truck it is goin on is offroad only
joey your talkin about Jamie right?
Logged
GiS
That CB Yapper
Tire problem
Reply #4 on:
January 04, 2007, 01:28:00 PM »
Jamie = Littleguyracing
Logged
Mudhawg
Rig Life
Tire problem
Reply #5 on:
January 04, 2007, 03:04:01 PM »
Any idea how much he will charge?
Logged
Print
Pages: [
1
Go Up
« previous
next »
4x4 Related Groups
Tech Talk
Tire problem
